Re: is fiberglass legal to use on a first robot?
With composite structures the orientation of the fibers affect it's characteristics. One problem with pultrusions is the large majority of fibers are in the length direction. Because of this point impacts are a problem with Pultrusions. This can be partially addressed by filling the pultrusion with 2 lb, 2 part expanding foam. With pultrusions a good way to increase the point impact strength and increase the load bearing capacity is with tube in tube construction. We took a 2" 1/8 wall and a 1" 1/8 square tube pultrusion. The 1" was inserted in the 2". The space between the 2 on one end was filled with epoxy and chopped carbon fiber for 4" and bolts where set in the epoxy to mount the hinge hardware. The space between the 2 tubes was then filled with the 2 part foam with in 6" of the other end and then that end was filled with epoxy fiber mixture. The resulting structure Has point impact resistance and is stronger than going to heavy wall units and is still very light. With composite work I would strongly recommend using an amine laminating epoxy and not polyester resins. The surface hardness and strength is much better with epoxy.
Fiberglass gets its strength from the glass fibers that make it. If you drill a hole in a fiberglass box beam, the glass fibers are no longer continuous, so you compensate the beam's strength. If you want to have a continuous box beam with cuts in it, you have to get it custom woven by a company, and that is pricey. I would stick to using fiberglass welding glue, or if you must, only drill screw holes in the very ends of the beam. That way you retain as much of the beam's strenght as possible.
![]() Last edited by mechanicalbrain : 28-09-2005 at 22:23. |
#7
![]() The other thing that may affect the strength is the thickness of the epoxy. The thicker the better to a point, and we laid it on thick, then laid it over a mold and let it cure. |
#8
Fiberglass is a very generic term. A lot of people think of the polyester resin and chopped glass. In airplanes we use woven cloth and a two part epoxy. This epoxy has a much greater pot life, and gives you time to smooth everything out. A couple sources for materials to learn with: Wicks Aircraft and Aircraft Spruce have a composite kit which includes a manual from Rutan's plans. The kit includes epoxy, cloth, different types of foam, and some flox and micro balloons. Another source for epoxy and cloth is at West Marine stores. The West System epoxy with slow hardner works quite well. We have used fiberglass laid up over a large salad bowl (about 4 layers of 7 ounce cloth) to make 'hands' to grasp a large ball. 2000 game, maybe? We also used about 12 layers to reinforce some plywood to make a spring as part of a ball thrower mechanism. |
#10
As this thread is showing composites is a deep subject. That is why I suggest that any teams that are interested in using composites should do the research and testing now. There is allot to learn and the build season is too short to perfect composite methods unless your team has a someone with experience. Every year I have mentor I have work a composite structure in some where on the bot to give the students an exposure to this important technology. I would like more teams to work this in to their robot too. A good start would be to take a 1' by 1' piece of 1/4" birch plywood and laminate 1 layer of 6 oz s glass on both sides and do some testing to see what this simple process does to the plywood. I can post some sites to help. If they like the results they can go from there. Get some fiber in your robot's diet.
#12
Drilling a couple of bolt holes in the side is a recipe for disaster. If you must do something like this, drill through the top and bottom rather than the side. Use big washers to spread the clamp loads and torque the heck out of it. The whole point is to minimize loads that tend to split the pultrusion open. Though if you do this you probably also want to fill the gaps between the rod and the pultrusion with epoxy or similar so that when you clamp down you don't break it in compression. Composites can be great materials but the real trick is getting the load in and back out. Bond whenever you can because bolt is a four letter word. Bolts lead to stress concentrations and tend to cause failures in unpredictable ways. Unless you use the specialized fasteners we do here at the bird farm, but $50-$80 each is a little expensive for most teams. |
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 29-01-2006 21:29 |
| 2005 FRC Team Update 14 | Jeffrafa | General Forum | 43 | 01-03-2005 15:52 |
| Manual placement of tetras | Petey | Rules/Strategy | 7 | 22-02-2005 18:04 |
| Legal Robot Design? | adventrx327 | General Forum | 10 | 09-03-2004 22:50 |
| Calling all Lawyers... ...Define "all parts" | Joe Johnson | General Forum | 10 | 13-03-2002 15:12 |
