Go to Post it's much easier to build safety in to a system than to add it on a Thursday at a regional. - dtengineering [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 29-09-2005, 21:31
Alex Golec Alex Golec is offline
FRC Advocate
no team (FiM Volunteer)
Alex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond repute
[OCCRA]: Shaft Couplings
Does anyone know what the bore sizes are in the shaft coupling?
_Alex
Unread 30-09-2005, 18:50
occra 23.
AKA: ryo
None #1481
Re: [OCCRA]: Shaft Couplings
which motor?
Unread 30-09-2005, 22:43
FRC Advocate
nevermind, we found that they were 3/8" in bore.
They are the steel shaft couplings that look like a super-long shaft collar with 4 set screws, we used them on out drill motors in 2003.
_Alex
Unread 01-10-2005, 22:30
occra 23.
AKA: ryo
None #1481
_Alex
ahh yes. i just realized that now that we dont use that for our drive. or maybe not use them at all theres really no reason to use 3/8 shaft. we still use it tho. hm.. would make more sense if we just bought 1/2 shaft for our axles next year. since our bearings are for 1/2 anyway. then we could skip the annoying process of using those brass bushing/spacers each time we go from 3/8 to 1/2.
Which shaft encoder to use? Jeff Waegelin Electrical 22 18-06-2005 03:57
pic: 571's new gearz loose weight CD47-Bot Robot Showcase 24 16-04-2004 16:35
Problem with 5/8 in. shaft in this years kit echos Kit & Additional Hardware 5 14-01-2004 21:21
Motor coupling archiver 2001 19 23-06-2002 23:35
