#17
Re: PRESSURE SWITCH
If you fire a large cylinder a few times rapidl, you will notice how quickly the system pressure (at the tanks) drops below 60 PSI, even when you started at 95 - 115 psi. It takes a long time for the compressor to recover and your cylinders may move slower while the compressor is trying to catch up.
If you limited your reservior pressure to 60 psi, the system might never recover during a match if you were trying to operate pneumatics. |
| Pneumatic pressure switch | M. Hicken | Programming | 9 | 29-01-2005 23:35 |
| Pressure Switch: Ordering a Spare | Bduggan04 | Pneumatics | 4 | 22-03-2004 20:15 |
| connecting pressure switch | kingpin3787 | Pneumatics | 2 | 19-02-2004 21:01 |
| spike for pressure switch? | Rob Colatutto | Rules/Strategy | 4 | 23-02-2003 15:42 |
| Error found in programming for the pump and pressure switch | sjharobotics | Programming | 4 | 06-02-2002 17:46 |
