Thread Tools |
Rating:
Display Modes |
Re: What kind of wheels do you use?
Team 57's trying some new wheels in the off-season.
http://204.2.107.191/good_year_power...cing_tires.htm They're go-kart tires. Solid neoprene around an aluminum hub. They're really gripy, as long as they're clean, and the rear pair has a hole that mates with a shaft with two flattened sides, so it should be fairly easy to use. |
nice thread, its giving me some ideas...anyway
what 1403 used last season was a 5" x 1" rubber wheel from McMaster-Carr, the advantages though a bit heavier were that we could staple teflon to any of the wheels that we wanted to so they could be used to slide around a bit. As well as they had no spokes at all really so were very durable. The wheels generated more than enough friction with the carpet to move around. However for the upcoming season we are looking into a waffle tread, our research is showing that there is some good results with it. |
They have REALLY good grip (no one was able to push us once we fixed our limit switch). I remember at VCU that we held 345 (Blarg!) and all they did was spin tires and burned the carpet. ![]() |
| What kind of materials do you use for your wheels? | Alex Cormier | Technical Discussion | 1 | 24-01-2005 19:19 |
| Who Likes Wheels? | Rob | Technical Discussion | 22 | 06-05-2004 23:49 |
| Four Wheel, all steering, non-omniwheel, ONE power/motor source drive | FizMan | Technical Discussion | 31 | 27-04-2004 12:12 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
