Go to Post Remember to have fun! That's what the FIRST experience should be for you- a lot of fun while doing a lot of learning. - smurfgirl [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 02-10-2005, 18:58
LordBritten's Avatar
LordBritten LordBritten is offline
Lord Britten strikes again!!!!
AKA: Matt Britten
FRC #0949 (Wolverin Robotics)
Team Role: Driver
LordBritten is an unknown quantity at this point
Multidirectional Wheels Yes or No??
My team is thinking about using Multidirectional Wheels or Omni Wheels.
what do people think about them. if you do not know what they are go to
www.omniwheel.com
http://www.andymark.biz/am-trick.htm
Unread 02-10-2005, 19:12
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Multidirectional Wheels Yes or No??
Teams have used them with good results in the past. If you want to do the extra work, go for it!
However, my team has never used them.
Unread 02-10-2005, 19:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
It really depends on the application. What is the game/challenge you are considering them for? What are you trying to do? Turn better? Obtain translational movement without heading direction change? Omni wheels can help you achieve things things but there are some definite downsides as well.
In a square 4 wheeled omni robot, you will only get a maximum of about 70% of the motors' power contributed to moving the robot in the direction it is going. The other 30% is lost due to vector cancellation. But maneuverabily is outstanding, but it doesn't follow that controllabiltiy will be as well. This must be taken into consideration. It will take some good programming and driver practice to be able to maneuver it effectively and accurately.
Who Likes Wheels? Rob Technical Discussion 22 06-05-2004 23:49
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
wheels, wheels, wheels.... Jesse Control System 1 05-02-2004 15:00
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
