Go to Post FIRST is doing a great job, it's me who needs to do the hard work now. - Bomberofdoom [more]
Unread 02-10-2005, 20:36
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
pic: My wheel/leg design
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 02-10-2005, 20:39
Morenoh149
Posts: n/a
Re: pic: My wheel/leg design
GREAT! Just a thought ...
you'll need some pretty sophiticated stuff to be able to stop the robot.
In the show the robot kinda turn and difts to a stop
Unread 02-10-2005, 21:30
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
From a more practical standpoint, if you make that entire shaft spin, you'll be putting a terribly large load on the bearings and shaft. Ball bearings are intended to support mostly radial loads. With your current design, the shaft bearing at the top would see a large thrust load, which would drastically shorten the bearing's life if you don't over-spec the bearing by a lot. Also, keep in mind that flexible shafts aren't going to transmit much torque.
Unread 02-10-2005, 23:15
occra 23.
AKA: ryo
None #1481
i think a simple doublewishbone idea of a suspension would work just as well and simpler.
Unread 02-10-2005, 23:20
I specifically want a simple walking/rolling design.
Unread 02-10-2005, 23:54
Cpt_Dave_Lister
Posts: n/a
Just wondering but, could you explain how it works? It look pretty cool
Unread 03-10-2005, 00:19
Well the general idea is that their are four legs and the sit out at an angle from the robot. The entire leg can rotate on that gear (more symbolic of where it pivots then anything else). Also the rod is attached to that square coupler by a ball bearing and rotates. When it rotates the half sphere at the bottom acts like a wheel. Its just a conceptual design right now and not really possible due to the limits of last years kit but its a future plan. Not only could it have simple walking but the legs could start facing up and fold down to add significantly to the height of a robot. Basically I'm trying to come up with a simple walking robot that doesn't have the disadvantages of speed that most walking robots posses.
As mentioned its got a few engineering hurdles it needs to overcome but if i don't use something like this in FIRST then ill definitely do it privately because the idea has been bouncing around my head for quite some time i just never really developed it until now.
Unread 03-10-2005, 09:16
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
In what way does this "walk"? Iit just a wheel at the end of a shaft? Or can it also swing the shaft some how...
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 03-10-2005, 12:01
It "walks" by whipping around that large gear the shaft bracket is attached to. Mind you, it'd walk better if the leg moved in and out as well as around or something similar. Perhaps instead of starting from scratch on both counts, you should find some simple leg joints that work for people and then figure out how to put wheels on them?
Unread 03-10-2005, 19:31
Yes thats exactly how it works. As to the retracting part. It would have to involve a mechanical function so i can keep the motors to a minimum. I want it to come around back so it can clear stairs and such objects. Finally, If I added wheels to the end of legs it would need to be some type of pulley system and then again I run into having more then two motors a leg.
Unread 03-10-2005, 19:48
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
I you want to see a ton of different walking robot designs, check out this page. (You'll have to scroll down a bit.) I know that these are Lego creations, but the principles behind the walking robots can be adapted to a larger scale. IMHO, I would think that instead of rotating the entire leg around, do as Kevin Sevcik suggested, and make the legs go up and down, instead of in circles. Similar to this picture:
I know that it wouldn't be able to go up stairs, but it would have much less stress on the shafts.
Also, I am curious. What is the size of your leg?
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-10-2005, 21:06
Thanks for the link! Ill go through it. You see the point is that Im TRYING to do a wheel/leg and not just a walking design. Your typical walking robot is very, very slow. I want to have some type of wheels to give it a good speed and then legs to give it the best climbing available while using a minimum amount of motors. In answer to that last question, I was looking at making the legs 1' - 1.5'. Thanks agian for the link.
Unread 03-10-2005, 23:11
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
You may want to try a tri-wheel.
Essentially its three wheels centered around a point, 120 degrees apart at the center of each wheel. Two rest on the ground and all three spin. When you hit a stair well, the friction cause it to pivot around the center and climb up the step, in theory. I played with the idea but never built it, I'm gonna see if I can do it with the Vex kit I'm getting this weekend.
EDIT: I added a rough sketch.
Matt Krass
Unread 04-10-2005, 09:10
artdutra04's Avatar
I've built one of those before using Legos, and it worked pretty well. But there is one thing to remember when you build these. The wheels around the outside must spin faster than the center shaft. This will make the three wheels roll easily, but when an obstacle comes (like a stair), the force will then take the easier route and rotate the whole assembly (instead of the indiviaual wheels).
If you are interested, here is video of a Lego Tri-Wheel robot climbing stairs: http://www.visi.com/~dc/tristar/stairs4.avi
There are more pictures on this page:
Art Dutra IV
世上无难事,只怕有心人.
Unread 06-10-2005, 10:29
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Got whegs?
http://www.chiefdelphi.com/forums/sh...ighlight=whegs
Courtesy of researchers at Case Western Reserve University in Cleveland, OH.
Have fun putting wheels on the ends of these things!
pic: my more specific design mechanicalbrain Robot Showcase 6 29-06-2005 22:39
Team 862'sEDUbot Design competition GhostInTheShell Off-Season Events 4 26-06-2005 18:10
Programming a 2nd PIC ImmortalAres Programming 8 16-06-2005 12:13
pic: 1305 Frame design with trannies CD47-Bot Robot Showcase 19 25-09-2004 01:13
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
