Go to Post Some companies cut costs (and cut corners to do so). Some work hard to build loyal customers. Which would you rather purchase from? - sanddrag [more]
Unread 03-10-2005, 12:19
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
pic: 1" mecanum
Unread 03-10-2005, 12:20
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: pic: 1" mecanum
Wow, I see a vex version of Jester..........
-Sir Francis Bacon
-Albert Einstein
Unread 03-10-2005, 12:23
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: 1" mecanum
OK i looked at this a few times and i have to know how you they are going to build this. I mean come on you are talking about a wheel about the size of a soda cap. i am impressed you designed it but this is one of those situations where is it worth it. i am guessing at least a 30 min per wheel Assembly time. having just finished my battle bot endeavor a while back and seeing how "quick and dirty" alot of the bots are IMO this is way over thought for the comp.
anyway good job on the design, but i still can;t see the application.
also if these ever get build we "have" to see pictures because i will be truly impressed
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 03-10-2005, 12:48
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: pic: 1" mecanum
i'm curious about the screws...are you going to machine them after the wheels already been assembled? if not, how are you planning to make the radii of the screws line up with the radius of the wheel?
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 03-10-2005, 13:23
AKA: Ty
Re: pic: 1" mecanum
it's polycarbonate hubs delrin rolers and nylon screws. the hubs will be made by drilling the 7 dowell holes first. a block of aluminum is drilled with the same pattern and clamped to a cnc. you use dowell pins in the holes to mill with the head at a 45 when you dinish a pass you unclamp the hub pick it up rotate it and line it up with the pins clamp it again and make your next pass. the screws are a cheat they are just the shafts for the rolers basicaly and the heads have to be razorknifed off because they stick out too much.
Unread 03-10-2005, 13:37
JMH's Avatar
JMH JMH is offline
AKA: Jereme Henson
FRC #1370 (Blue Charge)
JMH is an unknown quantity at this point
Send a message via AIM to JMH
Re: pic: 1" mecanum
Nice design I wish my team would create something like that but we never would
Unread 03-10-2005, 17:48
Re: pic: 1" mecanum
"if you can dream it you can do it" nothing is stoping you from designing something like that. if you need help there are plenty of people here willing to lend a hand.
Unread 03-10-2005, 21:58
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Re: pic: 1" mecanum
Cool Tytus very cool. I see you have gotten away from the 2 part hub design this looks very new and improved. As always let me know if I can help.
Ttyl and good luck,
Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 04-10-2005, 13:44
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Re: pic: 1" mecanum
I love delron. We used it to great effect in our 2005 bot.
A cool thing we found, if you pressure cook it in machine oil, it will leave a nice sheen behind (really).
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
PIC 18F2431 Sparks333 Programming 9 24-08-2005 01:24
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
