Go to Post And, if you don't know what something means, say so, we'll be happy to explain. - DonRotolo [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 02-10-2005, 17:02
Cpt_Dave_Lister
Posts: n/a
Re: What kind of wheels do you use?
Originally Posted by Cory
We've used 3/8" but only because we drive the wheels and not the shaft.
Does that mean the wheels turn freely on the shaft? And that the shaft is stationary?
Unread 02-10-2005, 17:15
Bharat Nain's Avatar
We use custom made, open cell skyway wheels. We then make diamond shape cuts on them so we have enough traction on the field.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 02-10-2005, 17:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Correct.
Bearings are pressed into the hubs, and a sprocket bolted to the side, with the shaft mounted through two blocks, rather than having the shaft mounted through pillow blocks, and then the sprocket bolted to the shaft, with the wheels fixed.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-10-2005, 18:45
LordBritten's Avatar
LordBritten LordBritten is offline
Lord Britten strikes again!!!!
AKA: Matt Britten
FRC #0949 (Wolverin Robotics)
Team Role: Driver
LordBritten is an unknown quantity at this point
What do you people think about
the Multidirectional wheels or
Omni Wheels
Unread 02-10-2005, 19:08
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Omni wheels are great! If you want lots of traction while using them, then you must design them using the right materials.
In the 2003 and 2004 we built a 4 wheel drive to 2 wheel drive conversion for our robots.
We built these conversion mechanisms so we had better maneuverability and so it was easier to turn.
This year we decided against using them because it took time to deploy them.
So we used two pneumatic tires in the front and two omni wheels in the back.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 02-10-2005, 19:26
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Originally Posted by Kevin Sevcik
Team 57's trying some new wheels in the off-season.
http://204.2.107.191/good_year_power...cing_tires.htm
They're go-kart tires. Solid neoprene around an aluminum hub. They're really gripy, as long as they're clean, and the rear pair has a hole that mates with a shaft with two flattened sides, so it should be fairly easy to use.
Go-Cart tires sound somewhat familiar...
They have REALLY good grip (no one was able to push us once we fixed our limit switch). I remember at VCU that we held 345 (Blarg!) and all they did was spin tires and burned the carpet.
Unread 03-10-2005, 02:05
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I'm more than willing to bet that our team (1501) had some of the cheapest wheels. We used 4" PVC pipe covered in conveyor belt material. The ends were PVC caps with 6 blind nuts for mounting the drive gear.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 03-10-2005, 08:14
Billfred's Avatar
Billfred Billfred is offline
I had kicked around this concept in my head, but I wasn't sure how up to the task the pipe would be. How did they hold up?
Unread 03-10-2005, 09:41
Andrew Blair's Avatar
FRC #0306 (CRT)
We use an wheel typically used in elevators to keep the car on track, with a modified rubber compound. They are some of the grippiest wheels you can get for the carpet, but I don't know how'd they be against those racing tires!
Heres an example: Two years ago (using the same wheels and a 120lb bot), we pulled a minivan (Caravan?) on worn smooth pavement with no problems or slip.
-Sir Francis Bacon
-Albert Einstein
Unread 03-10-2005, 18:45
330 typically uses the kit Skyway wheels, but adds belting. This year, however, we used four of the six-inch Skyways and ground almost all of the tread off so they'd slide when we turned, then used some heavy tires (I don't know where we got them) in the center, one on each side.
Unread 03-10-2005, 21:36
mgreenley
Posts: n/a
For the years I have been on the team, I think we've used 6-6.25in diameter, 2in wide (80, but it might be 60 durometer solid rubber tires). Most years they've had treads, but for FIRST Frenzy they were smooth.
On a side note, I don't think we've ever tried to pull a vehicle with our robot...but , There's a whole season ahead of me and a spiffy idea to try out...was the van in or out of gear at the time of the pull?
Unread 03-10-2005, 22:04
Cory's Avatar
AKA: Cory McBride
I'm guessing it was in neutral. plenty of teams have done this before, it's really not all that hard, actually. Once you get it started, it's pretty easy.
It'd be darn near imossible to pull a car that was in gear. I doubt any FIRST robot ever built would be able to. The only one that would have any chance would be 71's 2002 bot, with like 5 people piled on top.
2001-2004: Team 100
Unread 04-10-2005, 20:51
FRC #0306 (CRT)
I'd imagine it was. I was just an onlooker, not actually involved at the time (still in fll). I was just amazed that it didn't slip the wheels when starting. And it wasn't a particularly slow start. I guess some decent pnuematic tires would do a good job too.
-Sir Francis Bacon
-Albert Einstein
Unread 10-10-2005, 15:45
Best Available Data
FRC #1778 (Chill Out!)
We had 6 inch rear wheels made by an offroad skateboarding company. They worked great but they don't have an amazing life span. We noticed today that they are almost grip free but they did work great for 1 regional and 1 off season event. For front wheels we had 4 inch omnis that were like two single sets of omni's put together then offset. I'll look around for the company website.
Unread 10-10-2005, 16:40
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
we used 2 8in trick wheels (omnis) from andimark.biz on front and then we took some heavy duty casters and riped the wheels off them for the back
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
What kind of materials do you use for your wheels? Alex Cormier Technical Discussion 1 24-01-2005 19:19
Who Likes Wheels? Rob Technical Discussion 22 06-05-2004 23:49
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
