Go to Post All I can say is - we are such geeks! - Raul [more]
Unread 04-10-2005, 11:06
muy dificil muy dificil is offline
FRC #1611
muy dificil is an unknown quantity at this point
cmucam2
has anyone tried to use a usb to serial cord for the cmucam2 on a laptop and got it to work. how do you get the laptop to recognize that its coming from the usb port
Unread 04-10-2005, 15:28
Dave.Norton Dave.Norton is offline
FRC #1157
Dave.Norton is an unknown quantity at this point
Re: cmucam2
Well you can't use the adapter that came with your mouse, the protocol is different. The mouse logic is setup to be either a USB or a serial port, and uses voltage level to sense which mode it is in. The good news is you can buy an adapter: http://www.provantage.com/buy-7tdwu0...9-shopping.htm. This is one I found by googling USB serial adapter.
Unread 05-10-2005, 10:43
FRC #1611
Re: cmucam2
never mind we found out our problem
calibrating a cmucam2 muy dificil Programming 2 19-09-2005 12:46
CMUcam2 interfacing Kram Programming 2 27-05-2005 07:17
CMUCam2 code (FRC and EDU?) Amber Programming 0 15-02-2005 22:23
CMUCam2 Vision Sensor Testing/Problems cbolin Programming 18 02-02-2005 18:03
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
