Go to Post Being a good engineer isn't all about engineering. It's about being able to use engineering for a practical application, and to successfully communicate your research or development results to people who aren't engineers - Jon Stratis [more]
Unread 05-10-2005, 23:35
Non Contact Magnetic Encoder with PWM Output
http://www.austriamicrosystems.com/0...try/AS5040.htm
I stumbled across this today...
Apparently, this company austriamicrosystems makes an IC which can measure the rotation of a magnet (resolution of 1024 parts per revolution). It has an onboard processor and A/D converter, and does all the stuff we would to do process encoder data in our robot code right on board the chip. It can output rotation data in quadrature, SSI, or PWM.
I cant seem to find how much this costs, but they will send free trials to corporations.
This is the first I've seen of this type of sensor. Does anyone know a little more, or think this may be something worth looking into? As far as I can see (without money on the mind), something like this could simplify our bot's code by leaps and bounds and give a much easier means to closed loop control, with less chance of error or breakage.
Compiling Failed Teh Mike Programming 7 09-02-2005 13:27
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Fading LEDs using a PWM signal from the Edubot DanL Programming 22 30-03-2004 00:07
