Go to Post Originality in Sponsorship can get you a lot of places. - MysterE [more]
Unread 28-09-2005, 20:10
KarenH's Avatar
KarenH KarenH is offline
Mrs. ChrisH
FRC #0330 (Beach 'Bots)
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
Storing the VEX Kit
Now that the robo-maniacs in my too-full house have acquired their very own VEX kit, I have one "vexing" question:
How shall we store it?
Using the original packaging is, of course, unworkable.
Using the original box, minus the Styrofoam, sounds possible, but where would we store an assembled robot?
We're thinking of getting some kind of large plastic box, big enough to hold a "square bot" lying on its side, plus a smaller organizer box that would fit inside the bigger box.
Any suggestions? Good places to buy such boxes?
Karen Husmann
Ex Robo-widow
Unread 28-09-2005, 21:52
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: Storing the VEX Kit
This is where the Rubbermaid type containers come in handy. While a select few have dividers your best bet is to see what they have in different gallon/quart sizes so the one will fit in the other. You may be able to fit several small ones inside a larger one and still have room for the robot.
I've purchased many of these different containers over the years for storage of car parts, model trains and even X-mas decorations. Walmart, K-mart, Target, Costco, BJ's and several other stores generally have these on sale often.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 04-10-2005, 14:40
Schmoebot's Avatar
Schmoebot Schmoebot is offline
FLL & FTC Coach
FRC #1135 (WHS Robotics)
Schmoebot is an unknown quantity at this point
Karen,
I picked up a large plastic tool box at Big Lots for $5. Everything fit nicely inside, with the exception of the controller. Then I saw the tool box used by Wendy Wooten of High Tech High (FRC team 22). She found one at Walmart for $8 - $9, the controller and the robot both fit inside, and the small parts containers on top are removeable, so the box does not tip over when you open it during use! I recommend Walmart.
Cogito; ergo, condo.
"I think; therefore, I build."
Unread 04-10-2005, 15:22
KarenH's Avatar
Mrs. ChrisH
Team Role: Parent
Originally Posted by Schmoebot
Karen,
Wendy Wooten of High Tech High (FRC team 22)... found one at Walmart for $8 - $9, the controller and the robot both fit inside, and the small parts containers on top are removeable, so the box does not tip over when you open it during use! I recommend Walmart.
Thanks for the tip! Now that we have a Walmart near us, we can go see if they have what we need.
I learned yesterday about the tipping over part. You do have lovely toolboxes, and we'll be getting them back to you shortly, minus most of the glitter...
Aaahh--errr--pray that your team never gets assigned next to a hair styling booth at the fair. Our booth neighbors had a gizmo for wafting glitter onto customers' hair. We were downwind. The glitter wafted downwind.
But if you do get such an assignment, here's a way to break the intense static bond between the most stubborn glitter flecks and the plastic of the tool box: Use a Post-It note, and "dab" it onto the little buggers. They will stick to the note instead of the plastic. Shining a flashlight on the surface helps you see if you got all of the glitter.
Vacuuming doesn't get it all. Water doesn't get it all. Brushing it off only makes it worse.
At least the VEX robots are tough enough to withstand such environmental hazards.
Karen Husmann
Ex Robo-widow
Unread 05-10-2005, 13:48
Ken Delaney 357 Ken Delaney 357 is offline
FTC #101(Radnor Robotics)
FRC #0357 (Royal Assault)
Ken Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to behold
On the poster that comes with Vex starter kit a Vex Carrying Case is listed in the equipment section. I would be interested in seeing what that looks like. I myself have gone in the direction of the plastic tubs and storage trays. I use one of the tubs from Stack Attack. If you cut a piece of 1/4 inch plywood to fit inside the tub it can act as shelf by sitting on the molded indentations of the tub.
“Far better it is to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor spirits who neither enjoy much nor suffer much, because they live in the gray twilight that knows not victory nor defeat.” ~Teddy Roosevelt
Thus spake the master programmer:
"A well-written program is its own heaven; a poorly-written program is its own hell."
Unread 05-10-2005, 21:14
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Team 45 uses a Plano Tackle box for their extra parts. Some of the bigger stuff we keep in the original box.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 06-10-2005, 14:09
KarenH's Avatar
Mrs. ChrisH
Team Role: Parent
I'd be interested in seeing it, too, but I couldn't find it on the VEX web site. It wasn't on their Accessories page, at any rate.
But then again, I couldn't find the Search feature for the web site.
Karen Husmann
Ex Robo-widow
Unread 06-10-2005, 14:26
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
IF it was released as a product, you would see it on radioshack.com by searching "vex". It has not been released, but was highlighted as a potential product. Maybe we'll see it in the future.
John
Unread 11-10-2005, 23:08
KarenH's Avatar
Mrs. ChrisH
Team Role: Parent
Thank you all for your input! For the record, Chris and I went to Wal-Mart and purchased:
--A Rubbermaid "Duratote" 83L bin
--Two Plano model 3750 tackle boxes. They are flat, about 13 inches long--long enough to hold the long bars, but not the long angle bars. They have lots of adjustable compartments.
The tackle boxes and everything else fit in the Rubbermaid bin. While we were in the store, I wondered if the bin was too big. Room for expansion is good, but space for storing bins is limited.
Sure enough, the bin will not go into our Saturn's trunk upright. Of course we found this out AFTER we'd paid for the bin. Then again, we weren't planning to take the VEX kit anywhere in the car with us--or were we?
Karen Husmann
Ex Robo-widow
VEX Programming Kit Available On-Line Ken Delaney 357 FIRST Tech Challenge 6 02-10-2005 11:25
Vex programming kit finally available?? rswsmay General Forum 20 27-09-2005 22:08
Programming Vex Starter Kit To Recieve From Serial Port firetrap FIRST Tech Challenge 0 26-09-2005 17:27
First Time Here & Vex Robotics Kit jeffmorris General Forum 11 11-09-2005 20:38
VEX EDUbot hybrid or $50.00 VEX kit? Tazlikesrobots Robot Showcase 15 13-08-2005 22:12
