Go to Post I am a big fan of community building exercises. And harassing my friends. - Amanda Morrison [more]
Unread 07-10-2005, 09:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: My wheel/leg design
Originally Posted by mechanicalbrain
Yes thats exactly how it works. As to the retracting part. It would have to involve a mechanical function so i can keep the motors to a minimum. I want it to come around back so it can clear stairs and such objects. Finally, If I added wheels to the end of legs it would need to be some type of pulley system and then again I run into having more then two motors a leg.
Finally getting around to answering this... You could obviate the need for tons of extra motors, pulleys, chains, flexible shafts, etc by going with a large, well designed leg, and then putting a motor/gear case/wheel assembly on the end of it. Using FIRST parts, it'd be some sort of sturdy leg system with a Nothin'-But-Dewalts motor assembly attached to a wheel at the end of the leg. There are trade-offs, obviously. This makes your leg much heavier. But on the plus side, electricity is an awful lot easier to bend around corners than mechanical rotation.
pic: my more specific design mechanicalbrain Robot Showcase 6 29-06-2005 22:39
Team 862'sEDUbot Design competition GhostInTheShell Off-Season Events 4 26-06-2005 18:10
Programming a 2nd PIC ImmortalAres Programming 8 16-06-2005 12:13
pic: 1305 Frame design with trannies CD47-Bot Robot Showcase 19 25-09-2004 01:13
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
