Go to Post Heck, every human being has the potential to change the world, as long as the world still exists. - [more]
Unread 06-10-2005, 15:09
REVving up for a new season
FRC #2848 (All-sparks)
Re: air speed sensor for rc plane
this is not really for a competition, it is a spin off project from Josh's employment that will probably be the ground work for a senior design project. The device is going to be used outside. and that picture is just an example not our final product. Although i think that the propeller counting might work outside still because of our low altitudes we are running there still wont be that much pressure difference, hence the reason we don't want to use pressure sensor to do speed.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 06-10-2005, 16:58
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Originally Posted by Greg Needel
...because of our low altitudes we are running there still wont be that much pressure difference, hence the reason we don't want to use pressure sensor to do speed.
Airspeed measurement has nothing to do with what altitude you're at. Well, as the air gets thinner, the conversion constant to convert your measured pressure difference into true airspeed is different, but the altitude makes no difference in the ability to measure it. If your airspeed is too low, that might be a problem, but the altitude is independent.
Your low change in altitude will make it easier and cheaper - you should be able to do a sufficient job with only one pressure transucer (the one at the pitot tube). Since your altitude changes will be small, you won't need to know the ambient pressure.
Unread 07-10-2005, 07:31
For outside runs, counting prop rotation will not give you repeatable results. Head winds and cross winds vastly effect air speed vs. ground speed. Without a correlation there you will not be able to run a course in auto. Is there a possibility for triangulation from the ground to be transmitted to the plane for course changes? That would allow you to save weight and computing by performing all the functions on the ground.
Unread 07-10-2005, 16:12
Gdeaver Gdeaver is offline
FRC #1640
One problem your going to have is that with that size airframe and power you have almost no electronics payload budget. If you go up in scale and to gas power, there are some off the self options. What I' m thinking off is a pocket PC with a GPS add on. The position, altitude, velocity, heading are available. Use the pocket PC as the main brain. Visual studio Ide can be used to program the pocket PC. The Intel processor has more power than a microcontroller. With the proper cable a pocket PC can out put serial commands. There are servo controller chips based on pic16's that can take the serial command from the pocket pc and generate the hobby servo PWM signals. A rs232 converted is needed. the next part is to use gyro's designed for helicopters and planes. There are single axis units and 3 axis units. They are what stabilizes the RC helicopters. With control of 3 axis, stable straight level flight is possible. These gyro's are designed to take PWM input from the RC receiver and mix these commands with the stabilizing out of the gyro to give smooth control. Release the joy sticks and the plane will return to straight level flight. The Pocket pc controlled servo chip replaces the RC receiver in auto pilot mode. Don't underestimate the magnitude and cost involved with this project.
Unread 07-10-2005, 23:43
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
www.eagletreesystems.com
also check rcgroups.com
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
Higher PSI in air Tanks Projectchon Pneumatics 8 01-02-2005 15:05
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
