Go to Post "If everything is possible, there is the possibility that something is impossible..." ::sigh:: :) - Kims Robot [more]
Go Back   Chief Delphi > Competition > Team Organization
Unread 07-10-2005, 16:06
Alex Burman's Avatar
Alex Burman Alex Burman is offline
∆o□
AKA: The Burmanator
FRC #0075 (Roboraiders)
Alex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud of
Send a message via AIM to Alex Burman Send a message via MSN to Alex Burman Send a message via Yahoo to Alex Burman
Button making
I am looking into making buttons for our team for the first time this year but am a little confused about all the machines that are out there. Is there really a difference between anyone of them. And can button backs and covers sold by different companies be used interchangeably between different machines. Also when it says the size of a button is is the radius or diameter. what button makers do your teams use and where did you get them?
The Burmanator
www.Roboraiders.com
http://www.myspace.com/burmanator
Unread 07-10-2005, 18:57
Best Available Data
FRC #1778 (Chill Out!)
Re: Button making
Originally Posted by Ians First Law of Button Making
Never ever ever, unless you plan to spend hours upon hours making buttons and generally torturing yourself, use the fully hand powered button maker. Get one that is at least semi-automatic.
Now I don't have the links right now but there isn't really a big difference (at least in my experience). One company makes the backs without their number on the back but for FIRST buttons, who cares? The size is done by diameter. I'm not sure of the model we use now but do not get this button maker. I'd say 1 in 10 buttons fell apart unless the person who was making them knew what they were doing (and that namely was pushing really hard and getting it lined up perfect). And even if you did it well a fair few still fell apart. And we had parents and students who slaved at least 10 hours making these buttons.
Unread 07-10-2005, 19:15
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: Button making
We have had this button maker for years now:
http://www.dickblick.com/zz608/06/
I recommend it, once you learn how to use it, you will have buttons made up in no time. This is great to because you can have several people working on the buttons at the same time. One person cutting the paper, one person loading the machine, and one person pressing the buttons together.
You can order the button blanks right from the same website, keep in mind you will also need a good circle cutter and the mylars.
I HIGHLY recommend these ones:
http://www.mrbutton.com/accessor.htm
Do not get one that has adjustable sizes because they are JUNK!
The machine looks expensive, but its worth it.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 07-10-2005, 20:17
Re: Button making
I think we use Badge-A-Minit. If everything is lined up right, and you use the right amount of force (pushing way too hard is not good, for you or the button), then you should get decent buttons almost all the time.
Tip 1: Don't try to do it in 30 seconds. You probably have a 20% chance of getting a good one.
Tip 2: If a button isn't horribly mangled, but is unusable as a whole, you may be able to use the parts after separating them and checking them.
A typical button-making session: Students show up, button machine is there and ready. One student takes the machine (two if we are really pressed for time), everyone else grabs circle cutters (trust me, they're a lot easier than using scissors and more accurate) and starts cutting out circles or sorting out backs, fronts, and covers. Hours later, we run out of something or do an arbitrary stop, with lots of buttons in bags.
Unread 07-10-2005, 22:05
kjhobin kjhobin is offline
AKA: Keith Hobin
FRC #3314 (Mechanical Mustangs)
kjhobin is a jewel in the roughkjhobin is a jewel in the roughkjhobin is a jewel in the rough
Send a message via AIM to kjhobin
Re: Button making
Dr. Don Buttons supplys
this is the best place 4 button suplys.
the buttonj mache they sell is really good. if you already have the papers cut out, you can make a button in 10 seconds. and about 97% of them stay together!
Montclair Robotics FIRST Team 555 Alumni
FIRST Volenteer
Unread 08-10-2005, 10:05
∆o□
AKA: The Burmanator
Re: Button making
thanks you have all been very helpful
The Burmanator
www.Roboraiders.com
Unread 10-10-2005, 21:42
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Button making
This is a robotics competition... Why hasn't anyone tried to automate the process yet?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 10-10-2005, 21:45
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Button making
Shh! Don't give away any game hints for 2006!
Button making companies? Alex Minot Team Organization 8 23-04-2005 18:20
Earn Your MOE 365 Personal Recognition Button in Atlanta! Mr MOE Championship Event 24 18-04-2005 10:10
Special button teaser... MissInformation Chit-Chat 25 06-03-2005 23:15
disabling a button gomez6760 Programming 1 12-08-2004 11:54
which button machine do you use and do you like it? KenWittlief General Forum 10 16-10-2003 00:01
