Go to Post if your robot weighs 1-1/2 tons, you have bigger problems then the legality of that jack... - ekapalka [more]
Unread 11-10-2005, 22:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Stuck sprocket - need advice
Okay, I've had lots of really stuck sprockets, hubs, gears, whatever in my time but nothing like this one. I'm trying to take apart this old lawnmower I have (to make a gokart) and one of the sprockets is so stuck on its shaft that it might as well be welded on. This would be a good thing in the future because it will be a drive sprocket/axle but right now it is bad because further down the axle there is a sprocket welded on, and between the two sprockets is a wheel that I need gone. So, I must remove the stuck sprocket to get the wheel off (and install a spacer in its place).
The stuck sprocket has two set screws at 90 degrees from each other which I removed completely. I've tried beating the shaft out of the sprocket. I've tried beating the sprocket back down the shaft (so then I could grind the shaft a little smaller). I've tried twisting it by holding it and the shaft with two Robogrip pliers (and I'm a strong guy too). I've tried WD40. And none of these methods even caused it to budge.
The only thing I haven't tried is heating. Should I give it a shot? I'm afraid the shaft might heat up too and that I could run into the problem of the shaft steel have a greater coeficient of linear expansion than the sprocket steel and that would make the problem even worse.
I don't have access to an arbor (or any other kind) of press right now. Only my muscles, and hammer, robogrips, dremel, sawzall, etc.
I don't really care about saving the sprocket (because I have an identical one) but I do need to save the shaft. So would it be possible to cut the sprocket off with something like a sawzall?
Unread 11-10-2005, 22:24
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: Stuck sprocket - need advice
have you tryed a gear puller?
also how hard did you hit the sprocket? maybe it needs the persuasion of a 20lb sludge
and you may wanna try cutting down the middle of the sprocket(like your trying the see the cross section) and stooping Cloe to the shaft, then take a wedge or crowbar and wedge it in and split it, but cut it on both sides first so one can break and the other can hinge.
Unread 11-10-2005, 22:52
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Have you tried a monkey wrench? I had a hell of a time getting the bolts off my bumper on my truck, and I used that and it worked.. It messed up the bolts, which I didn't care about..but it worked.
Plus, for lubricants.. there are better things than WD-40.
I can't think of the name of the one I used sucessfully many times already, but I'll try and get the name when I see it next.
Unread 11-10-2005, 23:02
By monkey wrench you mean like a pipe wrench right? I that would work better than Robogrips; I'll try it. For the penetrating oil, do you mean PB Blaster or Liquid Wrench? I've heard PB is good but have never tried it. I honestly don't know if there's a huge difference between LW, PB, and WD40.
Unread 11-10-2005, 23:11
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
I was just about to say, try using some Liquid Wrench... then see if you can use some type of hydraulic press.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 11-10-2005, 23:21
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
i had this problem too a while back, heres what i did... i got some PB "nut buster" and douced the heck out of the keyway/shaft and i let i sit for about 3 hours. then i came back and having the shaft vertically pointing up (mount the motor temporarily so the output shaft is vertical)
, i got a peice or square (or round) stock thats bigger than the shaft but smaller rthan the OD and got a peice of wood and gave it a couple of good whacks w. my 30lb sledge
the sprocket came off the key, and then i was able to remove the key and slide the sprocket of...be wary though you may shatter the sprocket or even bend it.
you could use an oxy-acetelene torch and heat the hell out of it and then beat it off try and get a few pics too...
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 11-10-2005, 23:22
I know liquid wrench, and I don't think it is liquid wrench.. Yes.. Monkey wrench=pipe wrench.
As far as LW and WD-40 go.. Wd-40 is like pouring water on the metal as far as unsticking (not worth it).. and they are both lame compared to the one I use.
Unread 11-10-2005, 23:25
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You could probably very carefully cut a wedge out of the sprocket.
You'd run the risk of possibly damaging the shaft if you don't stop exactly in the right spot.
I'd definitely stick to the penetrating oil and big ol wrench/sledge idea before resorting to hacking it apart, though.
2001-2004: Team 100
2006-Present: Team 254
Unread 11-10-2005, 23:29
Thanks Elgin, a pipe wrench did it. I never thought of that. I put one small pipe wrench on the axle and stood on it and took one big pipe wrench on the hub of the stuck sprocket and with nearly my entire weight on the small one (yes I almost lost my balance and fell over) and putting all I had into the big one and a little more WD40 I was able to break it free and now it can rotate all the way around without too too much trouble. I still need the wrenches to turn it, but it isn't too hard. From all my beating, I probably have enlarged the end of the shaft a little (yes I should have used a block of wood), so I'll probably still need a gear puller to get it off but at least now it is free, or at least certainly more free than it was before.
Will something like this work for getting it off? http://www.harborfreight.com/cpi/cta...emnumber=45977 It certainly seems cheap enough and looks like it would be a welcome addition to my toolbox (if it works). I'm not buying the "5 tons of pulling power claim"
but I certainly think it can live up to all 1299 cents I pay for it.
The sprocket is approximately a 20T #35 with hub on a 5/8" shaft
Unread 11-10-2005, 23:46
AKA: Mongo
that gearpuller would work fine, except i dont know about the quaility. most automotive stores carry them, so instead of paying for shipping go get one in store.
Unread 12-10-2005, 07:56
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
[quote=Greg Perkins]...and gave it a couple of good whacks w. my 30lb sledge
QUOTE]
whoaaa!!!! i Never knew there were 30lb sludges.
Unread 12-10-2005, 09:21
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
30 pound sledge: 30 pound sludge:
-dave
Unread 12-10-2005, 15:15
Evan Austin Evan Austin is offline
out of my mind, be back later
Evan Austin is an unknown quantity at this point
Hey Sanddrag,
If the shaft is flared on the end from hitting it even a little bit, a gear puller may not be enough to pull the sprocket off. Think of it this way, if the shaft gets flared out ten thousandths of an inch, that will be like trying to press together (or in this case, apart) an extremely hard press fit. Check the shaft with calipers to be sure. If it is flared, fix the end with a good file or a bench grinder.
My only suggestion for loosening the sprocket would have been to heat the shaft and sprocket hub area, then spray with penetrating oil while it is still hot. I know it sounds a little dumb to spray light oil on very hot metal but it has always worked for me and never yet caused a fire (emphasis on YET). Good luck with the go kart, that's gonna be fun!
Unread 12-10-2005, 15:52
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
-dave
Leave it to Dave to resort to pictures (they do paint a thousand words) to point out the subtle differences between "Sledge" and "Sludge". Thanks for the clarification Dave!!!
Unread 12-10-2005, 18:44
Well, I did enlarge the end of the shaft when I beat on it. That was my mistake and I don't know what I was thinking. I guess I was in a hurry last night because it was getting dark. I've done it the right way many times before, I'm not sure why I didn't this time.
Anyway, I bought the gear puller. They had a smaller one (4" I think) that was only $6.49 so I got it. That might have been a mistake. It fit fine and everything, but right away the bolts in the thing started bending. I think I snapped like 3 of them by the end of this ordeal. You get what you pay for I guess. Additionally, the metal pieces started bending.
When I was first starting out, the point on the tip of the gear puller screw was just forcing itself into the shaft instead of pulling the sprocket off. I'd say the tip went a good 1/8" into the shaft.
Anyway, what it finally took to get this thing off was one regular adjustable wrench on one of the legs of the puller (to keep it from rotating) with a cheater pipe on the wrench. And then a vice on the shaft to help hold it and the sprocket and the legs of the puller to keep them from rotating. And then a huge 15" adjustable crescent wrench (I've seen bigger, but this thing is a monster) on the hex on the puller screw. With all the strength I had put into that 15" adjustable crescent wrench, I finally was able to get this thing off the shaft. I then ground the shaft a little and the new sprocket slides on and off just great.
All in all, I hope I never have to do that again. Also, strangely enough, the puller has a lifetime warranty so I'm going to take it back and get a new one. I think I'll replace the bolts with Grade 8s though.
Need Advice on approaching big corps. about money Ben B Fundraising 8 05-04-2004 17:49
If set screws suck . . . Madison Technical Discussion 17 22-12-2003 19:19
Dirty Birds need advice DirtyBird213 General Forum 13 11-12-2003 21:24
advice on starting a team.. archiver 2001 1 24-06-2002 03:20
Regionals start in one week - final advice or tips Mark Pierce General Forum 2 02-03-2002 18:49
