Go to Post Don't you have some rovers to redirect or something Dave? - Rich Kressly [more]
Unread 12-10-2005, 03:18
Doogie's Avatar
Doogie Doogie is offline
Reconnaissance Captain
FRC #1388 (Eagle Robotics)
Team Role: Scout
Doogie is an unknown quantity at this point
Legal to add .c file?
Would it be legal to add a .c file to the code which contains functions that could be called by the autonomous AND user routines?
Unread 12-10-2005, 05:45
Bharat Nain's Avatar
Re: Legal to add .c file?
Yes it is perfectly legal to do so.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 12-10-2005, 11:16
Billfred's Avatar
Billfred Billfred is offline
<insert standard disclaimer here that it may change for 2006, so make sure to read the manual after Kickoff. but I'd imagine it's a relatively safe bet.>
Unread 12-10-2005, 12:56
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
...yes, it should work just fine. We do it all the time.
On a side note:
For good programming practice, you'll want to put the function prototypes of your functions into a .h file of the same name. Then #include the .h file at the top of the other files that you want to use the functions in.
Don't PANIC!
S. P. A. M.
Unread 12-10-2005, 20:14
Umm Errr...
Absolutely. Basically, you can do anyhting you want as far as code is concerned. There is nothing that is restricted. The hardware is designed such that there is no way you can screw up code in a way that would cause the E-Stop, team numbers etc to stop working.
1139 Alumni
Unread 12-10-2005, 23:27
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
In fact, (although not the best of programming practices) you can just create an .h file called "include.h," and put all of your other includes in it, and then just include "include.h" in your c files.
The drawback is that every file includes every header, which may not always be desirable, HOWEVER, for beginning programmers, this can simplify the process of "which files do I need to include?"
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 13-10-2005, 01:13
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Many software people consider this to be a very bad practice, and as such I don't advise it, especially for beginning programmers. No sense in starting off by picking up a bad habit.
Unread 13-10-2005, 01:40
Doogie's Avatar
Team Role: Scout
Alright, thanks a lot.
Unread 13-10-2005, 17:03
CJO's Avatar
CJO CJO is offline
It depends on the scope of your program. while I would never use it in a major project, the smaller PIC programs lend themselves to centralizaiton of some things, and it can really simplify the process.
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Aspartame shyra1353 Chit-Chat 8 20-01-2004 22:41
Dashv2.ocx dependency file now available archiver 2000 0 23-06-2002 22:00
Improving PBASIC: Request for Comments Greg Ross Programming 19 16-02-2002 22:14
