Go to Post And we drafted without computers...forget the calculators...we used slide rules...the punchcards piled up so high we needed more office space...and we programmed in three feet of snow...up hill...both ways - Rich Kressly [more]
Unread 11-10-2005, 01:44
Kevin Watson's Avatar
La Caņada High School
FRC #2429
EEPROM Code
I've just posted software that can be used to read and write the Electrically Erasable Programmable Read-Only Memory (EEPROM) found in IFI's robot controllers. The code can be found here: http://kevin.org/frc. As always, if you find a bug in the code or a problem with the documentation, please let me know.
-Kevin
Here's the readme file:
The source code in eeprom.c/.h contains software to read from
and write to the Electrically Erasable Programmable Read-only
Memory (EEPROM) contained within your robot controller's
processor. Storing information in EEPROM has the advantage of
being permanent, unlike Random Access Memory (RAM), which
gets reinitialized each time you reset or restart your robot
controller.
See the code in Process_Data_From_Master_uP() for an example
application of this software.
This source code will work with the Robovation (A/K/A EDU-RC)
robot controller and the FIRST Robotics robot controller.
The included project files were built with MPLAB version 7.20.
If your version of MPLAB complains about the project version,
the best thing to do is just create a new project with MPLAB's
project wizard. Include every file except: FRC_alltimers.lib
and ifi_alltimers.lib and you should be able to build the code.
Three things must be done before this software will work
correctly with your robot controller:
1) You need to add eeprom.c and eeprom.h to your project.
Do this by copying the two files to your project directory
and then right clicking on "Source Files" in the project
tree, selecting "Add Files...", if necessary, navigate to
the project directory and then double click on eeprom.c.
Repeat the above procedure for eeprom.h under "Header Files".
2) A #include statement for the eeprom.h header file must be
included at the beginning of each source file that calls the
functions in eeprom.c. The statement should look like this:
#include "eeprom.h".
3) The function EEPROM_Write_Handler() function must be called
from Process_Data_From_Master_uP() each time it executes.
Here's a description of the functions in eeprom.c:
EEPROM_Read()
Reads data from EEPROM.
EEPROM_Write()
Places new write data on the EEPROM write queue. This function
returns a value of one if there was an available slot on the
queue, zero if there wasn't. EEPROM_Queue_Free_Space() should
be called to determine if enough free space is available on
the queue before calling EEPROM_Write(). By default, there
are sixteen slots available. The number of usable slots is
defined in eeprom.h.
If buffered EEPROM write data is present (i.e., EEPROM_Write()
has been called), this function will write one byte to EEPROM
each time it is called. A call to this function should be placed
in and called each time Process_Data_From_Master_uP() is called.
If, on average, you need to write more than one byte of data to
EEPROM each time Process_Data_From_Master_uP() is called, you can
call it multiple times each loop. If you start experiencing wacky
behavior when your 'bot runs or get the red-light-of-death, you
might be attempting to write too much data too quickly. Because
it takes 2 milliseconds to write each byte of data to EEPROM and
all interrupts are disabled during this period, don't write data
to EEPROM when you need to service interrupts.
Returns the number of free slots available on the EEPROM write
queue. This function should be called to determine if enough
free space is available on the write queue before calling
EEPROM_Write().
Kevin Watson
http://kevin.org
Unread 11-10-2005, 19:46
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Re: EEPROM Code
THANK YOU!!!!!!!!!
(Bows and kisses Kevin's feet)
The possibilities are so good.
P.S. Do you know if this will work on the VEXtroller?
P.P.S: Did I say thak you?
(Rather than Double Post)
How does data need to be formatted when you pass it to the EEPROM_Write() function? Can you send variables by name?
Could you call this function using your printf/serial driver. For instance, type "Field Side: Left," and then have this set a variable (such as "rss" - robot start side") equal to 1 (for instance). And then have the handler write to the EEPROM so that when the robot is turned on again, it knows what side it is on without a switch.
Also, I am assuming that the read time is negligable compared to the write time (I.E. one does not need to woory about avoiding interrupts when reading?)
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 11-10-2005, 20:06
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: EEPROM Code
Sweet.
We were considering using the EEPROM when we ran out of code space last year, and this ought to make it a lot easier to do.
Thanks!
Unread 11-10-2005, 20:21
FRC #2429
Re: EEPROM Code
Originally Posted by CJO
...Do you know if this will work on the VEXtroller?
I haven't tried it. I'm not really supporting the Vex controller because it's a commercial product.
EEPROM_Write() is expecting a 10-bit address in an unsigned int and 8-bit data byte in an unsigned char.
If I understand your question correctly, yes, data will be retained even after you power cycle the robot controller.
Yes, reads are much faster than writes and you don't (as far as I know) have to worry about interrupts when reading.
-Kevin
Kevin Watson
http://kevin.org
Unread 11-10-2005, 20:51
FRC #2429
Re: EEPROM Code
Originally Posted by Greg Marra
Sweet.
Thanks!
Yes, EEPROM is a great place to locate, for example, trigonometric lookup table(s). A little piece of of code like this:
#include <math.h>
#include "eeprom.h"
unsigned int i;
unsigned char data;
//create a zero to ninety degree lookup table
for(i=0; i<=90; i++)
// wait, if necessary, for a free slot on the circular queue
while(EEPROM_Queue_Free_Space() == 0);
// normalize the output to the maximum value a byte variable can hold
data = (unsigned char)(255.0 * sin((float)i * 3.14159 / 180.0));
EEPROM_Write(i, data);
will generate one quadrant of a sine lookup table in EEPROM. Execute the code and you'll have a semi-permanent table in EEPROM that will allow you to very quickly solve sin(x) and cos(x).
-Kevin
Kevin Watson
http://kevin.org
Unread 12-10-2005, 01:18
CJO's Avatar
CJO CJO is offline
Re: EEPROM Code
Very cool, thanks.
Unread 12-10-2005, 11:53
kc8nod's Avatar
kc8nod kc8nod is offline
AKA: Ted Hansen
FRC #1216 (Knights)
kc8nod is on a distinguished road
Re: EEPROM Code
Hi Kevin,
Thanks for all the effort, it looks great and we'll definately be using it. I'd like to make one suggestion though.
With so many novice progammers using your code, it's likely that someone will use the EEPROM_Write() function too much, even when the data doesn't need to be updated. A small change to EEPROM_Write() might avoid problems for these folks.
unsigned char EEPROM_Write(unsigned int address, unsigned char data)
     unsigned char return_value;
     // determine if this is really new data
     if(data == EEPROM_Read(address))
          return_value = 1;
     else if(eeprom_queue_full == FALSE) // return error flag if the queue is full
          // put the byte and its address on their respective circular queues
          eeprom_queue_data[eeprom_queue_write_index] = data;
          eeprom_queue_address[eeprom_queue_write_index] = address;
If the new data being written, is the same as the old data that's already there, then we never add it to the queue.
Thanks again for all the hard work.
Unread 12-10-2005, 13:35
FRC #2429
Re: EEPROM Code
Originally Posted by kc8nod
Hi Kevin,
return_value = 1;
Thanks, it's a good idea and I considered it, but I'd also have to search the queue for writes to the same address as well, which would make the code a bit more complex. If I had to consider all of the wacky things that people do with my code and try to save them from themself, the code would be even more complex and bloated <grin>.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-10-2005, 19:31
CJO's Avatar
CJO CJO is offline
Re: EEPROM Code
So, to write "127" to the first data block would be
EEPROM_Write(1, 127)
and to get that value would be:
EEPROM_Read(1)
which would return 127?
Unread 12-10-2005, 19:59
FRC #2429
Re: EEPROM Code
Yes, that will work.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-10-2005, 20:19
Umm Errr...
Re: EEPROM Code
hrmm. I love the simplicity of this. Last year, i wrote overly complex EEPROM routines to allow data of arbitrary length to be stored with dynamic allocation and FAT table. It turns out, not a whole lot of that functionality was ever needed. A scheme like yours would have workded just fine. It makes me want to smack myself in the face and say "duh".
1139 Alumni
Unread 12-10-2005, 20:24
Re: EEPROM Code
How much variable is space is available in the onboard EEPROM?
Unread 12-10-2005, 20:40
Umm Errr...
Re: EEPROM Code
1024 bytes
1139 Alumni
Unread 12-10-2005, 22:53
FRC #2429
Re: EEPROM Code
#include <math.h>
#include "eeprom.h"
unsigned int i;
unsigned char data;
-Kevin
Ugh, I just realized this code will cause the red-light-of-death. Anyone care to venture a guess as to why it won't work? I'll post corrected code tomorrow-ish.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-10-2005, 23:22
CJO's Avatar
CJO CJO is offline
Re: EEPROM Code
It will write only when there is no free space in the write que?
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
