Go to Post The jags are powered with magic... - Aren Siekmeier [more]
Unread 12-10-2005, 19:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
pic: Beginnings of a gokart
Unread 12-10-2005, 19:46
Timmyd's Avatar
Timmyd Timmyd is offline
HAHA...i like pi
AKA: Tim
FRC #0022 (Double Deuce)
Timmyd is just really niceTimmyd is just really niceTimmyd is just really niceTimmyd is just really nice
Send a message via AIM to Timmyd
Re: pic: Beginnings of a gokart
hey instead of using a manual clutch i would use a 3/4 max torque clutch it will engage around 2100 rpms and it only runs about $40 its what i got on the cart i just built and it works great and for the muffler scrap it it kills hp to take it of you will have to take off the gas tank and carb first . instead off a muffler use straight pipe it will give you more hp and it sounds awesome
hey if you want it the way you got it ignore what i just said.
[center]Our robot's name is HOMER, it stands for Human Operated Mechanicaly Engineered Robot
Our team name is Double Duece 22
If all else fails... blame the PROGRAMER
Unread 12-10-2005, 19:47
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Hmm, all you need is one of those fuzzy things for the mirror and it will be complete.
(not sarcasm, really)
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 12-10-2005, 19:57
I was thinking about that but I've had the carb on and off so many times that I don't want to do it again. I'll try it with the muffler and if it's too laggy then I'll straight pipe it. Also, I don't want the neighbors to get too annoyed with all my engines (weedwhacker, RC car, minibike, truck).
For the clutch, I have one of those centrifugal ones on my minibike and while it is nice and easy to use, I don't really care for it. It slips too much for my liking. Plus it is money I would rather save than spend. Budget is the key for this project. I've got a V belt setup, so I'm going to try it.
Unread 12-10-2005, 21:06
Timmyd's Avatar
HAHA...i like pi
AKA: Tim
how much hp does the engine have with the clutch it should not slip as long it gets rpms . i used to have the problem with slippage it was due to the carburetors choke moving out of place so i zip tied it closed after that i tuned it it got up to rpms and took off but as you said their is the cost drive shaft sprocket and chain lots o cash most likely around $200 for the sprocket alone or at least thats what mine ran me
Unread 12-10-2005, 21:18
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Don't forget to double your horsepower with a NOS GoPed kit, it's good for 100cc engines I believe =P.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 12-10-2005, 21:22
Andrew Blair's Avatar
FRC #0306 (CRT)
Heres one important thing about your setup: i think those front wheels you have are the same ones we use on our go-cart, and they have a nasty habit of having the wheel separating from the hub. The small welds that hold the hub to the spoke portion break quite easily, but the wheel will not completley fall off. What'll happen is you'll not notice and end up rounding out the hole in the spoke portion, effectively creating a very nice piece of junk.
What you need to do is just remove the tire from the wheels and put some larger weld tacks on the hub. If you're careful you won't have to take the bearings out of the wheel, because that is a real #@!*. Avoid doing it at all costs.
Great idea! Try making it autonomous! Thats our little project, though it has been pushed to the side lately....
-Sir Francis Bacon
-Albert Einstein
Unread 12-10-2005, 22:01
Do you think I'll have any problems with the wheelbase? I'm trying to make it as short as possible but I'm a big tall person (like 6'2 or 6'3) so I need the length or my legs will cramp up. I just don't want to have any problems not being able to turn sharply enough though. The other thing I could do is make an elevated seating position so that my legs aren't as extended and the wheelbase can be shorter, but then the CG would be higher and the ride might not be as exciting because I won't be as close to the ground.
For the wheels, I have an identical one on the front of my minibike and the only problem is that the bearings went out but that was only after quite a while and at $5 each it isn't too big of a deal to buy a new one.
One other question I have is about the rear axles. Is it bad if the wheel bearing is riding on a fully threaded bolt? Can I put tape on it so the threads don't eat away at the bearing? Common sense tells me not to put a bearing on a threaded bolt/shaft but logic tells me that the inner race of the bearing will not be moving in relation to the bolt/shaft.
Another objective of this project is to do it with no or little welding, so the way I am thinking of doing the rear axles requires the wheel/bearing to ride on threads.
Last, does anyone know how I can make my own spindles without welding? Is it possible? Currently, I think that is the only part I would have absolutely have to weld (can't think of any other way) but if I can do the whole thing without welding that would be awesome.
Thanks for all the replies. Keep 'em coming!
Unread 12-10-2005, 22:09
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
i dont know if you saw the monster garage where the high school kids made the shopping cart/gokart. they had a really small wheelbase, and ended up not being able to turn, so what they did was free-wheel one of the rear tires on a bearing. it acted similar to a rear differential for their application, where i see it would be the same as yours. looks good, maybe blanket will be the next gen frame material
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 12-10-2005, 23:06
Timmyd's Avatar
HAHA...i like pi
AKA: Tim
the way you have the engine positioned makes it look like your going to only have one wheel drive ether that or your going to be above the axle. so i would move the wheels behind the engine and that wheel base is about the same as mine and i am about three inches off the ground and yet i can still hit the breaks and do 360s it should do fine if you have rack and pinion steering
Unread 12-10-2005, 23:54
Timmyd's Avatar
HAHA...i like pi
AKA: Tim
pics might help
ID:	3614  Click image for larger version
ID:	3615  Click image for larger version
ID:	3616  Click image for larger version
Unread 13-10-2005, 00:22
Thanks for the pics. I don't think you call that rack and pinion steering because there is no rack, and there is no pinion, but the pictured setup is the type of steering I plan to have.
How many HP is your engine?
The frame setup and wheel positioning on yours is interesting. It looks like you have your legs going over the tie rods. I might consider that. I was thinking of having the tie rods at the very front of the gokart and having the pitman arm and spindles pointing the other way and then having my pedals aft of the tie rods.
I'll have to sit on the ground and do some imagining to see what will work best for me.
Unread 13-10-2005, 00:31
Timmyd's Avatar
HAHA...i like pi
AKA: Tim
it is a 2.5hp engine but i plan on swapping it out for a 3hp that has been ported and polished as is it goes 30mph but with the new engine 35+
i hope
the steering wheel is not on it because it has a quick release so i can get out of it more easily a pin with a button release threw the steering column
Unread 13-10-2005, 16:32
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Hanging your legs over the front axle is very common is the Formula SAE competition. Just make sure you have a solid frame around them, to protect yourself from front end impacts.
You can see a lot of the pictures here...
Formula SAE Image Gallery
Bengineer
Unread 13-10-2005, 18:02
Kyle A's Avatar
Kyle A Kyle A is offline
If it ain't broke don't fix it!
AKA: K Adams
FRC #0306 (CRT(Corry Robotics Team))
Kyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud of
Send a message via AIM to Kyle A Send a message via Yahoo to Kyle A
[quote=sanddrag]Do you think I'll have any problems with the wheelbase?
I dont think that you will. On our go cart we have a small wheelbase and the only problem that you may have is with it skiding a little bit when we are turning.
Corry Robotics Team 306 1999-2015
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
PIC 18F2431 Sparks333 Programming 9 24-08-2005 01:24
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
