Go to Post so, i want the clue now, okay? is it bad that i am more interested in this years game than i am in taking my finals next week? - jwfoss [more]
Unread 13-10-2005, 09:52
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: EEPROM Code
Kevin,
I haven't tried this, but from the PIC documentation, it looks like you only have to disable the interrupts during the period that you call "pre-write sequence" and "execute the write" in the EEPROM_Write_Handler routine. You should be able to re-enable the interrupts after these 3 lines (from the 39609b Microchip document, section 7.4) rather than waiting until the 2ms write is complete. This may also eliminate the code error by allowing the high priority interrupts to mostly go on schedule.
Mike
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
