Go to Post So as you're thinking about this, think simple. - Cyberguy34000 [more]
Unread 12-10-2005, 19:14
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Stuck sprocket - need advice
Hey, somewhat unrelated but fun: the back of the PB blaster can has a melting styrofoam cup on it. It does what it shows too, in about 8 seconds. Went through about half a can and 6 cups playing with it. I'd imagine it would've done a good job on your sprocket.
-Sir Francis Bacon
-Albert Einstein
Unread 12-10-2005, 23:14
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Originally Posted by dlavery
30 pound sledge: 30 pound sludge:
-dave
I'd like to know where you got that one. My friend has one we use for smashing rock in the quarries for mineral collecting but he got it years ago from an old railroad equipment source, now gone. My biggest is about a 15 lb-er. Of course the Bosch 60 lb electric breaker hammer makes it much easier than both....
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 13-10-2005, 08:21
Sanddrag,
Sometimes pushing the sproket further on the shaft, then grinding down the mushroomed end works better than forcing it off.
Dave, sometimes you are downright scary. Although using the two together does bring back memories of Gallagher and a watermellon.
Unread 13-10-2005, 10:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I tired pushing (read: beating) it down the shaft but it wouldn't go. Yes, my methods are somewhat scary sometimes. When those bolts broke, they shot out a good 20 feet. And yes I continued to operate the device with bent bolts. Anyway, my scary methods are better then gnawing it off with me teeth though so what can I say.
Another scary project was using one of those thin plastic square Crystal Geyser one gallon water bottles as a 100psi storage tank (oh, and it was beautifully duct taped on). It was for a little air cannon. Anyway, I was waiting for the pressure to build up and thought "just a little more" and then the tank shot off of the piping arrangement and flew about 40-50 feet away. Surprisingly, the tank never ruptured despite how thin the plastic is.
Anyway, back to the sprocket. This sprocket had those two set screws, one of which going into a little bit of a hole drilled in the shaft. I think a previous owner of the mower must have jammed a rock in the blade causing the shaft to spin in the sprocket which made a nasty groove in the shaft (from the set screws) which resulted in the sprocket being incredibly stuck.
I'm glad it's all taken care of now.
Unread 13-10-2005, 11:36
I hate it when you follow someone who has screwed up the works and you have to fix it. (can you tell I have had to do this before?)
Unread 13-10-2005, 12:12
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
It's good to see the sprocket is off.
I know I'm late to the party here, but if this happens to someone again here are a couple more ideas to toss in. (don't you hate it when people give advice when it is too late?)
1. Heat up the sprocket. Alot. Try not to heat the shaft. The temp. difference between the two parts will enlarge the hole in the sprocket.
2. When beating on something you don't want to deform, use a brass hammer. I love my little brass hammer used to assemble gearboxes.
Andy B.
Need Advice on approaching big corps. about money Ben B Fundraising 8 05-04-2004 17:49
If set screws suck . . . Madison Technical Discussion 17 22-12-2003 19:19
Dirty Birds need advice DirtyBird213 General Forum 13 11-12-2003 21:24
advice on starting a team.. archiver 2001 1 24-06-2002 03:20
Regionals start in one week - final advice or tips Mark Pierce General Forum 2 02-03-2002 18:49
