Go to Post This year's rules != last year's rules. - GaryVoshol [more]
Unread 15-07-2005, 13:45
master master is offline
master is on a distinguished road
Post Which treads have an advantage?
At competitions teams had the exact same gearbox; but when a shoving match teams with treads won. I was wondering if anyone saw that also. And which tread is better Rough Top or Wedge Top?
Last edited by Madison : 15-07-2005 at 13:54. Reason: Fixed casing *again*. Don't change the casing or I'll just delete the thread. :P
Unread 15-07-2005, 14:01
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Re: Which treads have an advantage?
I have seen both designs work effectively at pushing. Aka S.P.A.M. this year and Cyber Blue in 04. I personally like the rough top it's better for turning and still gets the power to the ground. I am not sure which cost more but I am pretty sure rough top is cheaper. Also if you don't have a big budget I would not recommend treads.
my two cents,
Drew D.
Tech tigers
team#1251
Unread 15-07-2005, 16:15
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
i'm not sure the company we get our threads from..but the best ones we found where the white ones... which cost around 200 bucks each...
those threads we used this year and in the past and they have great traction...
Unread 15-07-2005, 16:42
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Roughtop vs. Wedgetop
I think they are about comparable when it comes to traction. I believe Roughtop has a little bit higher traction.
229 used Roughtop this year, for one simple reason: wear characteristics.
The Roughtop tread wears down much nicer than the Wedgetop while providing comparable (if not better) traction.
It is mostly a matter of preference. Some teams swear by one, some swear by the other.
Unread 15-07-2005, 19:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
my two cents,
Drew D.
Tech tigers
team#1251
roughtop and wedgetop are incline conveyor belting--which means they aren't suitable for use as treads, but rather as a traction material on wheels (You can get roughtop from Brecoflex, though). I think they're both pretty evenly priced, and it just comes down to personal preference.
2001-2004: Team 100
2006-Present: Team 254
Unread 15-07-2005, 20:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I've seen people say this so many times that I just can't take it any more. Unless you are talking about team shirts or forum discussions there aren't any threads to be discussed here. The matter at hand is treads (like referring to tank tracks) and more specifically tread (singular) referring to the traction enhancing material attached to the surface of a wheel. Thank you.
Now for rough top versus wedgetop, I would second most everything said above. Also, I don't think anyone has done any real testing between the two to determine which is better so most of it is probably just hearsay.
The wedgetop one does seem to be more popular. It does seem though that wear seems to be directly proportional to ground pressure which is inversely proportional to width. On wheels with 1.125" wide wedgetop we experienced no detectable wear whatsoever on carpet over the course of practice and one regional. However teams with .75" wide wheels with wedgetop have been known to have lots of wear and have to replace the tread during a regional.
One question that came up between a few of us is which way to run the diamonds with wedgetop. Because the diamonds are not simply rotated squares, they have a long diagonal and a short diagonal. So, what are the differences between running the diamonds long diagonal parallel with the circumference line and running the diamonds with the long diagonal perpendicular to the circumference line? Does anyone know? In a way I doubt that anyone really does know or has tested both ways
Unread 13-10-2005, 17:00
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
I've been thinking about the Roughtop vs. Wedgetop debate for the past few days. I'd be really curious to see some concrete data on this. Is there anyone out there who'd be willing to do a few traction tests? It'd make for a simple but very useful whitepaper. It could suffice for a simple science fair project as well. My hypothesis is that they both provide similar traction. Nevertheless, there has to be some reason that certain people swear that one type or the other provides considerably better traction.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 13-10-2005, 17:55
Cory's Avatar
AKA: Cory McBride
If you're talking about what I think you are, see Team 60's 2005 robot.
They cut their wedgetop so that the elongated side of the diamond was facing forward. I imagine they did it more for better wear characteristics than for better traction.
It takes a heck of a wide sheet to be able to do that though. Looking at McMaster's site, they only sell 18" width wedgetop, which isn't even enough to go around a 6" wheel.
2001-2004: Team 100
Unread 14-10-2005, 08:25
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
I just did some tests just last week. Roughtop gives a better coefficient of friction, from what my tests show. We are getting ready to sell 4", 5", & 6" diameter wheels with replaceable treads through AndyMark.biz. Here are my preliminary results:
surface: FIRST field carpet
weight on tread: 25 lbs.
tread size: 4"x1.5"
Material: Urethane roughtop, 0.20 thick
Max pull force to begin movement: 28 lbs
coefficient of friction: 28/25 = 1.1
Material: SBR wedgetop, 0.25 thick
Max pull force to begin movement: 31 lbs
coefficient of friction: 31/25 = 1.2
Material: SBR roughtop, 0.25 thick
Max pull force to begin movement: 33 lbs
coefficient of friction: 33/25 = 1.3
We are going through a website upgrade, so these wheels are not shown yet. Here are some specifics of our "Traction Wheels":
4" dia x 1.3" wide tread - $46
5" dia x 1.8" wide tread - $50
6" dia x 1.8" wide tread - $54
All 3 sizes have these qualities:
3/4" bore w/ roller bearing
Molded nylon body w/ fiberglass reinforcement
aluminum drive hub with sprocket mounting holes
aluminum sprockets as optional parts (35 series)
Treads can be easily replaced with screws
Once the site gets updated, I will post a link. These wheels will be available in mid-November.
Andy B.
Unread 14-10-2005, 12:38
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
IBApril did a traction test a couple of years ago and posted a white paper on the results. Go here: http://www.chiefdelphi.com/forums/pa...le&paperid=120to see what she came up with.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 16-10-2005, 23:59
Tammyanez's Avatar
Tammyanez Tammyanez is offline
AKA: Matt or Tammy (don't ask)
FRC #0060 (Bionic Bulldogs)
Tammyanez will become famous soon enough
Send a message via MSN to Tammyanez
Originally Posted by Cory
...see Team 60's 2005 robot.
Exactly. We found that putting the elongated side of the diamond "sideways" caused the tread to wear out much quicker. As for the supply for our tread, I am not sure, but the "wedgetop" tread seems to work well for our type of wheels.
Remember: you can catch more flies with honey than with vinegar... Of course, how you spend your leisure time is your business.
Unread 14-12-2005, 12:33
evolution's Avatar
evolution evolution is offline
FRC #0418 (LASA Robotics)
Team Role: Student
evolution will become famous soon enough
I'm having trouble locating the " urethane roughtop" on the McMaster-Carr website, that Mr. Andy Baker reffered to above. I checked page 1091 of the online catalog, where the other two are located, but couldn't find this material. Anyone know where to find it?
Also, last year, our team found that our 4 outer wheels, which had SBR wedge-top material, had two much lateral traction (this was really evident when we turned, the robot would wobble and hop). So:
1)Would it seem logical to drop down to urethane roughtop on the outer wheels to reduce lateral traction?
2)Would SBR roughtop perhaps have less lateral traction than SBR wedgetop, although it has greater in-line traction?
Unread 15-12-2005, 07:13
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We noticed the same. It was our first year using wheels with tread on them and the rough top SBR material gripped too much on the outer wheels and caused handling problems when turning, so we ended up replacing them with the harder nitrile rough top and life was much better. See attached pics...
So what is this urethane material Andy refers to? Is it the neoprene that McMaster sells?
Another question that has come up lately is why many teams are favoring the wider wheels - is it too reduce wear?
ID:	3727  Click image for larger version
Unread 15-12-2005, 17:57
evolution's Avatar
Team Role: Student
We used the SBR wedgetop last year, and we had to cut it by hand using an X-Acto knife and similar hand tools. When run through the bandsaw, it would basically act as a "brake" and stop the blade. How do you guys cut your wedgetop?
Unread 15-12-2005, 18:08
We tried cutting it on the bandsaw and the blade mostly just tried to suck it down/in. Then, we thought maybe we could turn it over for better results, but then it wouldn't slide on the saw table. So, we put it upside down (grippy side toward the table) and set it on top of a piece of paper on the table, and then it was able to slide easily and the saw cut it to perfection. It came out a perfect cut! Try using a fine blade meant for cutting metal so it doesn't catch the rubber and pull it down.
Tank treads, how we roll plutonium83 General Forum 6 08-01-2006 14:51
Has 6 wheeled designs surpased tank treads Andrew Schuetze Technical Discussion 60 27-04-2005 17:29
Tank Treads dddriveman Kit & Additional Hardware 27 06-05-2004 18:16
where to buy treads? illumanat'i Technical Discussion 11 11-01-2004 22:05
What problems have you encountered using treads? M.I. Technical Discussion 8 15-01-2002 22:13
