Go to Post Looks like we will be building a wood robot :) - IndySam [more]
Unread 12-10-2005, 22:49
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
pic: Vex 2 Speed Mesh Shifter
Matt Krass
Unread 12-10-2005, 22:51
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: pic: Vex 2 Speed Mesh Shifter
Awesome transmission. Lemme know when you can get the servo to shift it properly... I'll be trying to replicate your design then
Unread 12-10-2005, 22:56
Matt Krass's Avatar
AKA: Dark Ages
Thanks....I'll keep you posted..
Also, before I get any more comments about the redundant gears I know, I put them in there on purpose to try and reduce load since I had the extra gears and shaft space anyways. They are plastic gears....
Matt Krass
Unread 12-10-2005, 23:08
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
I am going to try to explain this right. As the picture shows, the output shaft is the same one as the shaft where shifting takes place. So wouldn't the shaft move back and forth (since it is mesh shifting and you got a wheel on the same shaft). How is that going to affect the wheel on the output shaft?
From what I am looking at, my suggestion would be to add a pinion gear (bunch of vex gears together) to the shifting shaft (on the right side of the picture, you might have to make the width of the tranny a bit bigger), and then mesh it with another gear on a new shaft. Make the new (third) shaft the output shaft.
Matt, I know you are limited to one vex kit. This was just a suggestion. So far you have done a great job. I like the way it is coming out. Figure out how you are going to shift and you got yourself a sweet little mesh shifter. Can't wait to see what you come up with next. Good luck.
Unread 13-10-2005, 01:19
Winged Globe Winged Globe is offline
Don't Panic
AKA: Xiao-Yu Fu
FRC #0481 (The Hitchhikers)
Winged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of lightWinged Globe is a glorious beacon of light
Send a message via AIM to Winged Globe
Very nice system. We also used a servo link when we built our prototype shifter for the spring Vex competition and it worked quite well. With only the starter kits, I think that's the way to go.
The material limit is definitely the hardest challenge. In order to accommodate the shaft movement, we vigorously ran a shaft through the center of an "output gear" to go on the shifting shaft. The gear was braced between the frame and another piece of metal. The shaft moved freely, and we didn't have any noticeable slipping of the gear. The output gear transmitted to a final wheel shaft on the exterior of the bot.
Why didn't it work? 1) We ended up needing all those gears for the arm, and we guessed that shifting would give marginal point benefit during the game. 2) We had a lot of shaft collars to make sure the gears didn't move, adding a lot of extra weight (though you may want to consider this if your gears get loose). 3) Plus, doing six-wheel drive by way of a nine gear gear train on each side in addition to the 3-speed shifter shot our turning efficiency to 0 (and again, no gears left). It worked wonderfully going straight, though... Haven't tried it with the sprocket and chain kit yet.
Can't wait to see your take on this (and with only 1 kit!).
Team 2B0
~O~
Unread 13-10-2005, 10:53
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
This is cool! I have a question though. Will this shifting gearbox be for a drive train application? If so, the way it is geared, it looks slow for a drive train. But it would make a killer arm gearbox.
Art Dutra IV
世上无难事,只怕有心人.
Unread 13-10-2005, 15:05
Michael Leicht's Avatar
Michael Leicht Michael Leicht is offline
Drive Coach
FRC #1403 (Cougar Robotics)
Michael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond repute
how are you going to keep the 2nd speed in gear?(with the servo and all)
what way do you have a shift so far?
nice design.
Team 303 (2003-2007)-Student-Won FIRST Scholarship to Daniel Webster College
Team 42 (2007-2008)-College Mentor
Team 2342(2008-2011)-College Mentor
Team 1403 (2011- )- Mentor
Unread 13-10-2005, 19:13
AKA: Ari
nice design.
As of right now (according to the pic), he doesn't shift the gears (you can, but only with your hand). He is working on making a piece that will help the shift shaft move back and forth, so it engages in different gears.
Unread 16-10-2005, 20:30
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Very nice work! Let us know how the gears hold up to some wear and tear.
Why are Arefin and you talking of a one kit limit. Is that all you have to work with? If so, stock up gear kits are $12.99!
I just rechecked the 2005-2006 rules and there is no limit on hardware components for this year's competition. Rule R5a,b,&c only limit you to one vex controller, eight servos or motors (the controller's limit), one battery pack, two RF receivers, and a small amount of non-vex material (rubber bands, rope, velcro, and non-slip pad). No other vex components have limits, other than the sanity limit... Beware the 60 pound vex behemoth!
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 16-10-2005, 21:04
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
It's actually pretty cool.
Vex is self-limiting in this regard. If you've got a 60 lb behemoth, you better stock up on motor clutches! Or... gear it at some super-slow speed.
(I wonder if you can even cram 60lbs worth of Vex into a 18x18x12 box?)
Unread 16-10-2005, 21:13
I'm baaaaaaack.
If you used a trash compactor you probably could
Unread 17-10-2005, 20:58
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
True. Vex motors are not very forgiving to over-design/over-building, but some teams will try and learn the hard way. How many threads were on the vexrobotics forum about stripping motor gears and broken clutches?
That's why the engineering notebook will come in handy. We usually learn more from our failures, than from our successes!
pic: 2 speed shifty on the fly Lego Bot CD47-Bot Robot Showcase 9 31-01-2005 04:21
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 23-04-2004 01:51
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 15:51
