Go to Post You have accomplished and learned more in the past six weeks than...a majority of people in the country. Be proud of your machine. Don't kick it to the gutter. Stand behind it. Believe in it. Give it your all. Take pride in your robot. :) - sanddrag [more]
Unread 13-10-2005, 22:33
Sidney San Martín's Avatar
Sidney San Martín Sidney San Martín is offline
FRC #0555 (Montclair Robotics)
Sidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura aboutSidney San Martín has a spectacular aura about
Autonomous: dongle?
Our team just bought three Vex kits for preseason new member training, practice, etc.
I'm looking through the docs online, and the one bit of information I can't find is autonomous usage. There's no information about dongles, and the competition controller schematic seems to be only for disabling.
How do we use autonomous mode?
Unread 13-10-2005, 23:03
Billfred's Avatar
Billfred Billfred is offline
Re: Autonomous: dongle?
For autonomous, just put a little red jumper in jumper port 13.
How enabling and disabling will work in this setup, I'm not sure.
Unread 13-10-2005, 23:04
Easy enough. Thanks!
EDIT: So wait... how is autonomous done in matches if it's controlled on the RC? It has to have worked somehow last season.
Unread 14-10-2005, 05:50
jeffmorris jeffmorris is offline
jeffmorris is on a distinguished road
I think that you don't have to put the jumper in jumper port 13 after downloading the program that was created in EasyC. One problem: How to make the robot wait for the user to put it on the floor after turning it on? If the program controls the motors, the motors run when the robot is turned on.
Unread 14-10-2005, 07:26
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I am not sure, but can't you replace the jumper with a switch?
If not, there are other work arounds.
How about programming in delay of X seconds?
You could also wait for some sort of switch transition to start the real work of the autonomous code.
Good luck.
Joe J.
Team #88, TJ2
Unread 14-10-2005, 08:29
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
I think FIRST is still working on this issue. Somewhere in one of the game manuals it said that all the information about how autonomous matches will work will be released in a later team update. Also, if you want to program autonomous yourself, you have to program in yourself which port you want the jumper to be on. Only in the stock, unaltered code will you need to use port 13.
For my Vex robot, I put a bumper switch on the robot. I will then program the autonomous behavior to trigger only if that bumper switch is pushed. (I just started programming last nght with EasyC. I have been able to get the robot to drive under manual control, and I have got the limit switches to stop the arm and elevator.) This way, I don't have to bring jumpers with me everywhere if I want to run autonomous.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-10-2005, 15:43
Thanks, all. We don't even have a programming kit yet. I just downloaded the default code from Vex Labs started looking through it, and saw the familiar autonomous loop.
I like the idea of either using a jumper combined with a bumper trigger or putting autonomous in the main loop.
But EasyC? Where are the real programmers here ?
Ach, I'll probably use it for some of the programming too...
Unread 14-10-2005, 15:51
The power switch on the micro controller should have three positions: off, on except motors and servos, and everything on. The Board of Education from Parallax has that kind of switch.
Unread 14-10-2005, 15:53
No. The Vex RC is only on/off. It's very different from the BoE!
Unread 14-10-2005, 21:14
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
I'm confused as to the question - at last year's Vex challenge, there was no autonomous mode - the robots were enabled and disabled via the tether port.
For this year, I was under the impression that the autonomous mode was run separately from the operated part - on a completely different field. Therefore, I guess you would just set a jumper when you are on the autonomous field and remove it when you are doing the user-controlled section.
For your own, you can do any sorts of things, including a switch, a photosensor with a light, set a delay in software. For Savage Soccer last year (http://users.wpi.edu/~savage/), a college mentor from WPI developed a RF controlled switch that did enable/disable and autonomous enable/disable (as there was no way to disable on the standard hobby radio transmitters).
Unread 14-10-2005, 21:23
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
official FVC technical forums are at http://www.vexlabs.com/forum
post your technical, including autonomous programming questions, there.
As for exactly how the competition will run, stay tuned.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
Setting Autonomous Settings from OI Tom Saxton Programming 15 27-03-2005 11:45
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
