Go to Post And now I'll just take a moment and say that you've all gone completely insane. That is all. - galewind [more]
Unread 14-10-2005, 05:37
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: Banner sensors
Originally Posted by sparksandtabs
what about sensing black/white?
You're trying to sense the colors black and white?
Are you trying to use the switch as part of an "encoder" (link 1, link 2) or are you trying to sense a black/white target? As in drive towards a black/white target and know the difference between the two.
You will still hook up the brown and blue as mentioned before, that won't change. Then decide between if you want to sense the white or the black color. This will decide which of the two remaining wires you will hook up to your input. You may have to experiment, depending on room lighting conditions, the distance between the sensor and the object (what the sensors rated for factors in here), and how the sensors adjusted (if adjustable) it may be able to pick up one color better than the other. You will have to switch input wires and try this out. Without really knowing what you're doing I don't see any reason to have both inputs from the switch. When it doesn't see the color you have it hooked up for it will assume the other, although this also depends on how you're programming it.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Encoders vs. Hall Effect vs. Banner Sensors Jeff Waegelin Electrical 7 03-08-2005 10:55
Wiring Banner sensors ten3brousone Electrical 6 01-03-2005 20:03
Wiring Banner Sensors ten3brousone Electrical 1 17-02-2005 03:16
Banner Sensors Padfoot Black Electrical 6 06-04-2004 10:06
banner sensors edomus General Forum 7 20-11-2003 19:43
