Go to Post Prepare to be surprised, amazed, awed, and inspired. - Alan Anderson [more]
Unread 15-10-2005, 15:58
Umm Errr...
battery voltage compensation
I was reading a document describing a specific control loop implementation when i ran across a mention of scaling the output inversely porportional to Battery voltage. When i read this an "AHA" lightbulb went off. This is something that can be implemented extremely easily on a FIRST robot and might be of some use in a few situations:
*any sort of timing based autonomous. Could make much more stable
*maintaining optimal tuning of a PID controller during times of low voltage either due to low battery or high motor load.
*might have some limited use under driver control. Humans will compensate for decreased sensitivity so it is probably unnecessary in this case.
Just an idea i thought i might share with everybody. We already have the voltage info available. It can't hurt.
1139 Alumni
DC Voltage indicator Don Wright General Forum 5 09-09-2005 07:52
Why MUST the 7.2v battery be attached to operate servos on the RC? Mike Rush Control System 17 06-02-2004 18:57
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
