Go to Post I can't get anyone on the team to leave warm South Florida to go to Manchester in January. Go figure. - Warren Boudreau [more]
Unread 15-10-2005, 17:40
Andrew Blair's Avatar
FRC #0306 (CRT)
Oscillating a pnuematics valve?
I was wondering if quickly oscillating a double solenoid valve would damage it after repeated use. The reason would be to create a multi-position pnuematics system using only 1 valve switching back and forth at the correct time, instead of controlling the exaust. Are the double's even fast enough to do this?So the question is has anyone done this, or is it unfeasible?
-Sir Francis Bacon
-Albert Einstein
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
Dump valve and pressure gage's tareyton Pneumatics 3 06-02-2003 21:13
Dismantle Solenoid valve? archiver 2001 2 23-06-2002 23:34
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
