Go to Post First is more than a competition it is a family. - amos229 [more]
Unread 16-10-2005, 14:09
Umm Errr...
Re: Oscillating a pnuematics valve?
Originally Posted by Eagle Master
The best way to do this is to use hydraulics, you can stop the cylinder at any place and it will be rock solid. If you want to do this for first, you need to get high presure on both sides of the piston or your set up will be spongy and not locate/hold location very good. You can make your cylinder way over sized to help make it stiffer. First's rules on pneumatics are very strick and really don't allow you to do much.
Haha true. Unfortunately we are not allowed to use hydraulics
1139 Alumni
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
Dump valve and pressure gage's tareyton Pneumatics 3 06-02-2003 21:13
Dismantle Solenoid valve? archiver 2001 2 23-06-2002 23:34
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
