Re: Calculus Query
grr math things like this frusterate my simple mind. I am no math person and i don't entirely understand why my solution is wrong. Maybie i am just stubborn. Lets define the inverse of a function as a being a function where f(x)=y and f^-1(y)=x for all x. By this logic if f(0)=0 then shouldn't f^-1(0) be 0 as well and shouldn't my solution work?
Re: Calculus Query
For a function to be invertible, it has to be bijective - "one on one" and "onto", that is, there's only one x value associated with a given y value, and that holds for every x. As an example, y = x^2 is not invertible, because for x = +- 2, y = 4. To think of it in another way, if you were to invert that function (rotate its graph about the line y = x), you'd get a function that, for one value of x, is defined for two y values. That is not a function. For a quick test, draw an horizontal line in this graph and sweep it up and down. If it ever touches two points on the curve, then the function is not invertible. You can see that your constant function does not meet the requisites for an invertible function. A Google search will provide thousands of good sources for information, this site is a nice one, with a simple explanation and pictures (who doesn't like pictures? )http://archives.math.utk.edu/visual....s/0/inverse.6/ Last edited by Manoel : 17-10-2005 at 01:43. |
Re: Calculus Query
I meant (and said) inverse, not reciprocal. This isn't an assignment, just something that occured to me during my endless and tedious BC Caluclus (anyone else have Early Transcendentals?) homework.
I've been trying to approach the problem visually, the inverse of a function being that function "mirrored" about the line y=x. I think perhaps this is needlessly painful, I'm going to try some algerbraic manipulation of the definition of the derivative... My guess is that no such function exists, but I wonder if there is an elegant proof of that. |
Re: Calculus Query
Re: Calculus Query
Let f be a function that is differentialable on an interval I. Suppose that f has a defined inverse function, called g. Using the defintion of an inverse, and the chain rule, it can be shown that g'(x) = 1/f'(g(x)), where f'(g(x)) != 0 This should help with you algebraic manipulation. |
Re: Calculus Query
You know what? I was tempted to try this problem, but my hatred of calculus overcame me while I was working some stuff out. Calculus tends to have more letters than numbers. This is math, not grammar... These letters also tend to not be in the English alphabet. Again, this is math, not a foreign language.
Today's episode of Sesame Street was brought to you by... The number e ...And, the letter mu. There also tends to be odd quirks. Take Gabriel's Horn. How can you possibly have something with an infinite surface area, infinite cross-section, but a finite volume!? And the volume isn't just finite, it happens to be a very specific number/non-English letter: pi. Yes, I realize the power of calculus. I also respect it. Seeing it work in physics still amazes me. But, I just don't like it. |
#7
Re: Calculus Query
This one is seriously making my head hurt. I recollect hearing a similar question proposed but my brain is too fuddled to remember the question in its entirety.
I say if 3rd semester Calc doesn't cover it, then it just isn't worth the headache. ...not yet, at least ![]() |
#8
Re: Calculus Query
Ok well I cannot find a way to definitly prove it but I can prove that this is never the case in the following cases.
x^n where n is positive x^n where n is negative all linear functions, All absolute value functions x^n when x is not an integer All trig functions All step (integer) functions of x Thats all I have time for now, Back to AP chem. |
#9
Re: Calculus Query
lets call f^-1(x) the inverse and (f(x))^-1 the recipricol
anyway Surely if you have f(x) which has powers in, when you differentiate it the power will decrease by one (unless your using e^x) reflecting it in y=x inverts the power (eg f(x)=2x^2+3 f^-1(x) = (x-3)^(1/2) / 2 as such differentiating it only lowers the power by 1 so you can't use integers as when you lower the power it won't be afraction if you want to try fractions, a/b - 1= b/a which the only thing that that has an equal distance from 1 on either side is 1/2 which would give 3/2 -1 (not equals) 2/3 so that can't work so not fractions i'm wondering maybe something hyperbolic or complex? |
#10
Re: Calculus Query
C'mon, guys, I haven't had calculus yet and I can tell you that there is a function like this. A function's inverse is its reflection in the line y=x, right? A function is any line or relation where any input has one and only one output, right? So a straight diagonal line is a function, correct? Now, the only function that will equal its own inverse has to have a slope of -1. So, any function whose equation reads something like f(x)=-x+b with any value for b will be its own inverse. Was that so hard?
#11
Re: Calculus Query
Re: Calculus Query
I stand corrected.
#13
Re: Calculus Query
Re: Calculus Query
| Calculus Students: Need Help with Precalc Lab | Jaine Perotti | Math and Science | 13 | 25-12-2004 23:32 |
| Link to FIRST's website for a "find all teams" query. | Elgin Clock | General Forum | 6 | 27-07-2004 09:00 |
| AP Calculus | Jack | Math and Science | 36 | 14-05-2004 17:13 |
| Member Query | Tytus Gerrish | CD Forum Support | 9 | 02-12-2003 20:09 |
| MySQL query question | Jack | Website Design/Showcase | 9 | 02-02-2003 00:11 |
