Go to Post you might want to consider the Edu-Robo-Whatevertheheckitscalled RC - Matt Krass [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 17-10-2005, 01:38
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Calculus Query
Originally Posted by Rickertsen2
grr math things like this frusterate my simple mind. I am no math person and i don't entirely understand why my solution is wrong. Maybie i am just stubborn. Lets define the inverse of a function as a being a function where f(x)=y and f^-1(y)=x for all x. By this logic if f(0)=0 then shouldn't f^-1(0) be 0 as well and shouldn't my solution work?
Rickertsen2,
For a function to be invertible, it has to be bijective - "one on one" and "onto", that is, there's only one x value associated with a given y value, and that holds for every x. As an example, y = x^2 is not invertible, because for x = +- 2, y = 4. To think of it in another way, if you were to invert that function (rotate its graph about the line y = x), you'd get a function that, for one value of x, is defined for two y values. That is not a function.
For a quick test, draw an horizontal line in this graph and sweep it up and down. If it ever touches two points on the curve, then the function is not invertible.
You can see that your constant function does not meet the requisites for an invertible function.
A Google search will provide thousands of good sources for information, this site is a nice one, with a simple explanation and pictures (who doesn't like pictures? )
http://archives.math.utk.edu/visual....s/0/inverse.6/
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 17-10-2005, 19:29
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Calculus Query
I meant (and said) inverse, not reciprocal. This isn't an assignment, just something that occured to me during my endless and tedious BC Caluclus (anyone else have Early Transcendentals?) homework.
I've been trying to approach the problem visually, the inverse of a function being that function "mirrored" about the line y=x. I think perhaps this is needlessly painful, I'm going to try some algerbraic manipulation of the definition of the derivative...
My guess is that no such function exists, but I wonder if there is an elegant proof of that.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 17-10-2005, 20:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Calculus Query
You mean the Stewart book? Yep, had that. I'd say it's not a bad book but there are some weird quirks every now and then where it won't explain some things very well. Mine came with CDs but I'd say they were pretty much useless.
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Calculus Query
The following fact will lead you in the right direction.
Let f be a function that is differentialable on an interval I. Suppose that f has a defined inverse function, called g.
Using the defintion of an inverse, and the chain rule, it can be shown that
g'(x) = 1/f'(g(x)), where f'(g(x)) != 0
This should help with you algebraic manipulation.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 17-10-2005, 20:56
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Calculus Query
You know what? I was tempted to try this problem, but my hatred of calculus overcame me while I was working some stuff out. Calculus tends to have more letters than numbers. This is math, not grammar... These letters also tend to not be in the English alphabet. Again, this is math, not a foreign language.
Today's episode of Sesame Street was brought to you by... The number e ...And, the letter mu.
There also tends to be odd quirks. Take Gabriel's Horn. How can you possibly have something with an infinite surface area, infinite cross-section, but a finite volume!? And the volume isn't just finite, it happens to be a very specific number/non-English letter: pi.
Yes, I realize the power of calculus. I also respect it. Seeing it work in physics still amazes me. But, I just don't like it.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 17-10-2005, 22:23
dubious elise's Avatar
dubious elise dubious elise is offline
Gone to school, back in 2016
FRC #0269 (Cooney Robotics); FLL #1855 (Cooney Tech/St. Jerome)
dubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond repute
Re: Calculus Query
This one is seriously making my head hurt. I recollect hearing a similar question proposed but my brain is too fuddled to remember the question in its entirety.
I say if 3rd semester Calc doesn't cover it, then it just isn't worth the headache.
...not yet, at least
"We can't guarantee success...but we can do something better, we can deserve it." ~John Adams
"The harder you work, the luckier you are." ~Gerald Ford
Notre Dame '10
Unread 17-10-2005, 23:36
Back after 4 years off
FRC #5279
Re: Calculus Query
Ok well I cannot find a way to definitly prove it but I can prove that this is never the case in the following cases.
x^n where n is positive
x^n where n is negative
all linear functions,
All absolute value functions
x^n when x is not an integer
All trig functions
All step (integer) functions of x
Thats all I have time for now, Back to AP chem.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 18-10-2005, 04:23
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Re: Calculus Query
lets call f^-1(x) the inverse and (f(x))^-1 the recipricol
anyway
Surely if you have f(x) which has powers in, when you differentiate it the power will decrease by one (unless your using e^x)
reflecting it in y=x inverts the power
(eg f(x)=2x^2+3 f^-1(x) = (x-3)^(1/2) / 2
as such differentiating it only lowers the power by 1
so you can't use integers as when you lower the power it won't be afraction
if you want to try fractions, a/b - 1= b/a which the only thing that that has an equal distance from 1 on either side is 1/2 which would give 3/2 -1 (not equals) 2/3 so that can't work
so not fractions
i'm wondering maybe something hyperbolic or complex?
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 20-10-2005, 15:31
Re: Calculus Query
C'mon, guys, I haven't had calculus yet and I can tell you that there is a function like this. A function's inverse is its reflection in the line y=x, right? A function is any line or relation where any input has one and only one output, right? So a straight diagonal line is a function, correct? Now, the only function that will equal its own inverse has to have a slope of -1. So, any function whose equation reads something like f(x)=-x+b with any value for b will be its own inverse. Was that so hard?
Unread 20-10-2005, 16:24
Manoel's Avatar
Re: Calculus Query
Well, you didn't read the question with enough attention. Phrontist wants a function such that its derivative is equal to its inverse, not the function itself.
No, not at all. My previous example of y = x^2 would not be a function if you were correct. You described a bijective function, but there are also injective and, the ones that disproves you, surjective functions.
Yeah, that is correct if you disregard the derivative part of the problem.
Brazilian Machine
Team # 383
Unread 20-10-2005, 16:45
Re: Calculus Query
I stand corrected.
Unread 20-10-2005, 19:42
Denman's Avatar
AKA: Stephen Denman
Re: Calculus Query
but you can only actually call it a function if its 1-1 in theory...
Unread 20-10-2005, 20:49
Manoel's Avatar
Re: Calculus Query
Care to elaborate? Not sure if I understand what you wrote...
Brazilian Machine
Team # 383
Unread 20-10-2005, 23:18
Re: Calculus Query
A 1-1 function (also written as one-to-one) is one that only goes down or up, not both, over its entire length. I don't understand why Denman says you can only call a function if it's 1-1 in theory, but he may know more than I do, which is quite likely. However, y=x^2 is a function, and it's not 1-1.
Calculus Students: Need Help with Precalc Lab Jaine Perotti Math and Science 13 25-12-2004 23:32
Link to FIRST's website for a "find all teams" query. Elgin Clock General Forum 6 27-07-2004 09:00
AP Calculus Jack Math and Science 36 14-05-2004 17:13
Member Query Tytus Gerrish CD Forum Support 9 02-12-2003 20:09
MySQL query question Jack Website Design/Showcase 9 02-02-2003 00:11
