Go to Post Try not to fall into the trap of choosing a material because it had the most supportive comments on CD. - Ty Tremblay [more]
Unread 16-10-2005, 21:31
Michael Leicht's Avatar
Michael Leicht Michael Leicht is offline
Drive Coach
FRC #1403 (Cougar Robotics)
Michael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond repute
vex programming arcade drive setting
i got the programming kit for my vex robot. and i starting programming my robot. i starting making a code for my robot for the arm and setting to the joystick. i got the limit switches programmed when it came to the drive system i put the arcade or the single stick and it is messed up. only one side moves when i move the stick forward. just not working out. if anyone can help me out with this problem by Tuesday night that would be helpful. i getting it ready for a demo. any one have an idea what i can do?
Team 303 (2003-2007)-Student-Won FIRST Scholarship to Daniel Webster College
Team 42 (2007-2008)-College Mentor
Team 2342(2008-2011)-College Mentor
Team 1403 (2011- )- Mentor
Unread 16-10-2005, 21:45
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Re: vex programming arcade drive setting
This post from another thread gives you an option
http://www.chiefdelphi.com/forums/sh...72&postcount=3
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 17-10-2005, 05:36
jeffmorris jeffmorris is offline
jeffmorris is on a distinguished road
On the tool bar just below the menu bar in EasyC, click on the button labeled "Pro". You should see additional commands in the window on the left side. Use "Motor Module Rx" and "Servo Module Rx". These commands allow you to assign any channel to any motor/servo.
Unread 17-10-2005, 21:26
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Have you tried downloading a simple While loop with just the Arcade motor command? Like the programming manual shows for Tank control (pg 8-46), only put in the Arcade - 2 motor control (assuming you are using 2 drive motors).
On my robot, the motors are on ports 3 (left) and 2 (right), so I used the settings Arcade2 (0,2,1,3,2,0,0) to map the right hand joystick left-right (ch1) to rotate and fwd-back (ch2) to forward/reverse.
Watch out that the Vex Help file example for Arcade - 2 motor has the transmitter channels swapped (fwd/rev to ch1, rotate to ch2). Makes for an interesting driving experience!
Pete Kieselbach
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
What should I put on my programming jump drive? IMDWalrus Programming 10 15-01-2005 13:37
Create a low speed drive in programming Bharat Nain Programming 11 17-10-2004 20:38
Globe gear box Pat Roche Motors 9 25-05-2004 22:50
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
