Go to Post It's not easy dealing with the reality that others aren't as passionate as we are and that the process may be slower than we want it to be - but it gives me plenty of time to think and prepare. - JaneYoung [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 18-10-2005, 23:28
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Lightbulb Linear slides
The use of a telescoping or vertical lift system has been avoided by our team since our rookie year back in 2001. We had tried using the tape system with the window motor glide system but we needed a lot of help.
I have been looking at some samples sent to our team from igus and those new parts donated by them to BEST. They look pretty solid and easy to use.
Does anybody have any experience with these types of items? Here is a flash animation from their website that really looks adaptable
http://www.igus.com/dwflash.asp
This is a page with pictures of the many examples shown in the flash movie.
http://www.igus.com/show_dw.asp
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 19-10-2005, 00:24
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Re: Linear slides
APS
Most people have the most trouble with these sort of things when they don't understand the accuracy required. The first part of that flash demo shows two round rails connected to a solid piece and the second part shows a couple round rails on separate pieces. I would strongly suggest using a single piece rail because of how tight you need to hold your parallel tolerance - very likely this is in the thousandths of an inch range, depending on the rail system.
I have a personal, relatively unfounded bias toward 80-20 extruded aluminum and their linear bearings in FIRST applications. Though a bit pricey, the linear bearing on the 1" size extrustion has force ratings that are appropriate for FIRST, are pretty forgiving in terms of misalignment and don't require lubrication.
But to answer your question - from a first glance, this looks descent. Check out the force ratings and make sure it'll hold up to what you need. The even more important (IMHO) design question is, how are you going to make that carriage move? I think finding a rail setup is the easier part of a linear system.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 19-10-2005, 00:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Linear slides
Team 294 quite effectively used heavy duty industrial drawer slides for their vertical telescoping action this year.
Team 980 (also quite effectively) used round aluminum tubing where one precisely fit inside the other and they drove it in and out with a timing belt.
Unread 19-10-2005, 09:32
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Linear slides
Team 617 used Drawer slides, too. They were preaty cheep at $12 for 2 large slides from Lowes. The tricky part is installing them. You will probably need to get other screws than what is supplied and make sure they work. Inside clearences are tricky. There should be a pic/movie on our site.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 19-10-2005, 10:11
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Linear slides
There are many ways to accomplish a reliable telescoping system. You can build both square and round "tube in tube" systems like teams 175 and 980, and a host of others. You can purchase off-the shelf drawer sliders and the like, similar to 111, 294, and 1071. We personally used the 8020, 1" linear bearing with much success. You can see examples of it on our website, along with teams 56, 103, 222, and many others.
I'm not all that familiar with the IGUS system, though I know that many teams use their products, again with much success. Tolerances are the key, as is maintaining the proper overlap between the two pieces. The more you extend one leg with respect to the other, the stronger the bearing needs to be, and the tighter the tolerances need to be. We tend to keep a 4:1 ratio of extended length to overlap.
If you need more detail or answers to specific issues, let us know.
Bengineer
Last edited by Ben Piecuch : 19-10-2005 at 17:26. Reason: Removed 696 from team list
Unread 19-10-2005, 15:58
Re: Linear slides
Originally Posted by Ben Piecuch
You can build both square and round "tube in tube" systems like team 696
As much as I like hearing that number, I must make the correction that we did not make a telescoping arm of any sorts. Haven't ever built one really, tried once in 2002 and failed. In 2005 we built a double jointed (shoulder and elbow) using very thin (.040) sheet aluminum bent and riveted together so we could get a very lightweight, thin-walled, yet still strong arm.
Anyhow, carry on.
Unread 20-10-2005, 19:32
Re: Linear slides
As much as I like hearing that number, I must make the correction that we did not make a telescoping arm of any sorts. Anyhow, carry on.
Is the previous post referring to linear slide mechanism that was not a telescoping arm
Mere speculation on my part
APS
APS
Founder FRC 499
Unread 20-10-2005, 20:13
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Linear slides
I believe 1072 used them on their robot in 2005, you may want to contact one of them -- Veselin Kolev visit's these boards once in a while, maybe you can drop him a PM.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 20-10-2005, 20:52
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Linear slides
A great solution is the Item linear slides. If your already using item extruded, you simply put the nylon sliders into the extruded and away you go. We did this in 2004, and it worked great. We got completely flipped up off the bar and fell to the ground, but our mast had no problem performing the naxt match. Item also sells some nicer, bearing/rail type carriage stuff too, although I have no experience with that.
item
-Sir Francis Bacon
-Albert Einstein
Unread 21-10-2005, 22:04
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Re: Linear slides
For the past 2 years I've built my teams arms, all of which are telescoping. We use extruded aluminum. If you have any questions or need any help just PM me. If your only doing 1 extension it's quite easy, but as you get to 2 or 3 extensions, it gets a little tricky. You can use both cable and chain. As of right now I only know how to use chain for 1 extension , but i hope to change that soon.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 18-01-2008, 23:37
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Re: Linear slides
3 stage IGUS Drylin system. Worked pretty well except the winch had to be rewound by hand(foot) after every match.
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
pic: Linear bearing + mount Alex1072 Robot Showcase 6 02-02-2005 11:13
Linear amplification through transisters? dddriveman Electrical 9 24-01-2005 09:55
Fourier Transforms phrontist Math and Science 14 30-11-2004 10:24
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Linear slides Gui Cavalcanti Technical Discussion 4 02-01-2004 15:59
