Go to Post I don't care if my team wins. I care if they try their hardest to win. - pfreivald [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 17-10-2005, 23:36
Back after 4 years off
FRC #5279
Re: Calculus Query
Ok well I cannot find a way to definitly prove it but I can prove that this is never the case in the following cases.
x^n where n is positive
x^n where n is negative
all linear functions,
All absolute value functions
x^n when x is not an integer
All trig functions
All step (integer) functions of x
Thats all I have time for now, Back to AP chem.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 18-10-2005, 04:23
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Re: Calculus Query
lets call f^-1(x) the inverse and (f(x))^-1 the recipricol
anyway
Surely if you have f(x) which has powers in, when you differentiate it the power will decrease by one (unless your using e^x)
reflecting it in y=x inverts the power
(eg f(x)=2x^2+3 f^-1(x) = (x-3)^(1/2) / 2
as such differentiating it only lowers the power by 1
so you can't use integers as when you lower the power it won't be afraction
if you want to try fractions, a/b - 1= b/a which the only thing that that has an equal distance from 1 on either side is 1/2 which would give 3/2 -1 (not equals) 2/3 so that can't work
so not fractions
i'm wondering maybe something hyperbolic or complex?
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 20-10-2005, 15:31
Re: Calculus Query
C'mon, guys, I haven't had calculus yet and I can tell you that there is a function like this. A function's inverse is its reflection in the line y=x, right? A function is any line or relation where any input has one and only one output, right? So a straight diagonal line is a function, correct? Now, the only function that will equal its own inverse has to have a slope of -1. So, any function whose equation reads something like f(x)=-x+b with any value for b will be its own inverse. Was that so hard?
Unread 20-10-2005, 16:24
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Calculus Query
Well, you didn't read the question with enough attention. Phrontist wants a function such that its derivative is equal to its inverse, not the function itself.
No, not at all. My previous example of y = x^2 would not be a function if you were correct. You described a bijective function, but there are also injective and, the ones that disproves you, surjective functions.
Yeah, that is correct if you disregard the derivative part of the problem.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 20-10-2005, 16:45
Re: Calculus Query
I stand corrected.
Unread 20-10-2005, 19:42
Denman's Avatar
AKA: Stephen Denman
Re: Calculus Query
but you can only actually call it a function if its 1-1 in theory...
Unread 20-10-2005, 20:49
Manoel's Avatar
Re: Calculus Query
Care to elaborate? Not sure if I understand what you wrote...
Brazilian Machine
Team # 383
Unread 20-10-2005, 23:18
Re: Calculus Query
A 1-1 function (also written as one-to-one) is one that only goes down or up, not both, over its entire length. I don't understand why Denman says you can only call a function if it's 1-1 in theory, but he may know more than I do, which is quite likely. However, y=x^2 is a function, and it's not 1-1.
Unread 21-10-2005, 00:18
Manoel's Avatar
Re: Calculus Query
Well, that's not the definition of a one-to-one function; in general it is, indeed, a consequence of the function being one-to-one. However, it does not apply to every function. For example: y = x^3 would be one-to-one by your definition, but, if you consider its complex roots*, then it is not.
* - For the record, I never had much of a formal, theoretical education on complex numbers, just its practical applications. Therefore, I may be wrong on the above statement.
Brazilian Machine
Team # 383
Unread 21-10-2005, 04:42
Denman's Avatar
AKA: Stephen Denman
Re: Calculus Query
sorry my bad i meant one-many, as long as its only one on the start so you cant get 2 values of f(x) for the same number.... however when you take the inverse (eg y=x^1/2) you need to limit your domain and so would need to limit the domain/range of the original function anyway
Unread 21-10-2005, 11:02
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Calculus Query
A one-to-one function is a function that has only one value of y (f(x)) for every value of x. You could also say that it passes the "horazantal line test" where if you were to draw horizantal lines, each would only pass though the graph once. One-to-one functions are important becuase they are functions that, when inversed, are still functions. y=x^2 is a function, but not one-to-one becuase f(1) and f(-1) have the same value. y=x^3 is one-to-one becuase no values of y repeat themselves. You can inverse y=x^3 and still have a function.
y=x^3 becomes x=y^3 when inversed.
x^(1/3)=y thus is also a function.
"One-to-one" comes from the fact that there is one value of x for every value y and one value y for every value x.
Nothing says that a functions has to be one-to-one. To inverse it and still have a function, yes. But a functions has to pass the virtical line test: if virtical lines were drawn, they would pass though the graph no more than once.
y^2=x passes the horizantal line test, so you can inverse it and have a function, but doesn't pass the virtical line test so it, in itself, is not a function.
The opposite is true of y=x^2. Is a function, but can't have the inverse be a function. Infact, it is the inverse of the above, but it isn't a function on the traditional x-y axis.
Things have been drifting, but I felt the need to clear the air about what is a function and a one-to-one function.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 24-10-2005, 01:34
Manoel's Avatar
Re: Calculus Query
Well, turns out there is such a function.
y(x) = 0.743*x^(1.618)
I took a more formal approach to the problem that didn't get me anywhere, so I talked to a buddy and here's what we found.
Explanation.
As you see, nothing formal. A mathematician will say it isn't a proof at all, but it does show that there's at least one said function.
PS - My statement on a previous post that y=x^3 was not bijective is wrong.
Brazilian Machine
Team # 383
Unread 24-10-2005, 07:33
Denman's Avatar
AKA: Stephen Denman
Re: Calculus Query
thats scary
do you know what 1/2(1+sqrt5) is!?
shudders
rep point for that
Unread 24-10-2005, 15:01
Manoel's Avatar
Re: Calculus Query
thats scary
shudders
rep point for that
Amusing, isn't it?
Of course, it isn't just a coincidence, it's a consequence of what we tried to do. We wanted an exponent n with the same characteristics as the Greeks wanted, just for different purposes.
Brazilian Machine
Team # 383
Unread 26-10-2005, 14:39
Leo M Leo M is offline
#0384 (Tucker Tigers)
Leo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really nice
Re: Calculus Query
Absolutely brilliant, Manoel! This is what I love about First. When phrontist in Virginia can put out a terrifically interesting question from Virginia, and have answers come in right on point from the UK and Brazil – well, we didn’t have anything like that going for us when I was in high school.
Manoel, however did you think of approaching the problem this way? You show extraordinary mathematical insight in choosing the right form for f(x). And phrontist – what made you think up this question? It’s absolutely first rate – you’ll do just fine at MIT when you get there.
For those who struggle with these concepts like I do, the inverse of a function exactly “undoes” what the original function did to the variable. If you perform a ‘function operation’ on a variable x, then follow up with the ‘inverse function operation’, you get the original x back.
So, if f(x) = 0.743 * x^1.618, and we take the first derivative,
then f’(x) = 0.743 * 1.618 * x^0.618 = 1.202 * x^0.618.
But, if f’(x) = Inv-f(x), we can substitute f(x) into the inverse function and get the original x back :
Inv-f(x) = 1.202 * ( f(x) )^0.618 =? x
Inv-f(x) = 1.202 * [ 0.743 * x^1.618] ^ 0.618 = 1.202 * 0.743^0.618 * (x^1.618)^0.618
= 1.202 * 0.832 * x = x, just what we started with.
So, the derivative of f(x) is the same as the inverse of f(x), just as Manoel showed us.
If we keep differentiating – which we can do as long as x >= 0, we can learn some interesting things about these functions, slopes, inflection points, concavity, etc.
f’(x) = 1.202 * x^0.618
f’’(x) = 0.743 * x^-0.382
f’’’(x) = -0.284 * x^-1.382
From x=0 to infinity, the function f(x) increases continuously, as does the first derivative/inverse. But f(x) approaches infinity much faster than the derivative.
From f’(x) we can see that the slope of the function f(x) approaches infinity as x gets larger and larger. Eventually, f(x) is heading almost straight up.
From f ’’(x) we can see that the function is everywhere concave upwards, as f’’(x) is positive for all x>0. But f ’’(x) is the slope of the first derivative/inverse, so we can see that the inverse always has a positive slope. But f ’’(x) goes towards zero as x gets larger and larger, so the slope of the inverse goes to zero, i.e., the inverse function approaches a horizontal line. Not an asymptote, however – the inverse function can be made as large as desired by taking large enough values of x. There’s no upper limit for it, so no asymptote.
From f ’’’(x), which is always negative for all x>0, we can see that the inverse is always concave downwards.
(Manoel – you might want to re-check your graph of these functions. It’s always a good idea to double-check computer generated graphs.
Note that the function is numerically equal to its first derivative/inverse when x = 1.618.
A magical number, to be sure. More interesting properties than can be addressed here.
I haven't had this much fun since the last First competition.
Leo M.
Calculus Students: Need Help with Precalc Lab Jaine Perotti Math and Science 13 25-12-2004 23:32
Link to FIRST's website for a "find all teams" query. Elgin Clock General Forum 6 27-07-2004 09:00
AP Calculus Jack Math and Science 36 14-05-2004 17:13
Member Query Tytus Gerrish CD Forum Support 9 02-12-2003 20:09
MySQL query question Jack Website Design/Showcase 9 02-02-2003 00:11
