Re: quick question as a newbie
ok, thanks a lot, that helps!
oooh. so that's what it means, huh? ok cool.
dont slam me if im wrong here, but your ranking points are, if you lose, 0. if you win, it is your opponents score. that is how its done in first. i know, just like the league i'm in now, the scoring is different in other offseason leagues
The rules for awarding Qualifying Points and Ranking Points have evolved over the years. Excerpted from The 2005 Manual, Section 8.3.3:
Ranking points are the same as a win loss record in other sports, FIRST just assigns points to help simplify calculations. Match or qualifying points are the tie breakers, If you score 100 points and your opponent scores 10 then you get 2 RP and 10 qualifying or match points, your opponent gets 0 rp but still gets those 10 match points, this means that even though your very strong alliance was able to score 100 points another team that won 26 to 25 is in much better shape than you are in overall standings. |
Wetzel |
#7
ok to end all confusion:
RP is "Round Points". You take your opponents score and that is the tiebreaker after overall win-loss-tie. So if my record is 4-4-1 and another team is 4-4-1, the team whos opponent on average scores the most points is the leader. |
| a quick function question | Kashi Chan | Programming | 3 | 06-03-2005 20:44 |
| A quick IR sensor question | PBoss | Programming | 7 | 28-03-2004 21:02 |
| can you use Carbon Fibre? | Greg Perkins | Technical Discussion | 9 | 05-02-2004 14:15 |
| Quick Newbie Question | Gobiner | Programming | 5 | 16-12-2002 12:49 |
| A quick question | Joelster | Technical Discussion | 6 | 10-02-2002 09:09 |
