Go to Post FIRST is a life lesson on steroids. - JohnBoucher [more]
Unread 23-10-2005, 17:18
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Victor 884 won't go forward
Originally Posted by KenWittlief
when you spin a motor (backdrive it) it acts like a generator. We use to demo this with the globe motors and the old rotating lights - hooking them together, turning the globe motor with a wrench and the rotating light would lightup and spin
during an event when you let off the joystick, the motors back-feed, and depending on whether you have your victors set to coast or brake, the counter-EMF (generated voltage) from the motors will either be shorted through the victors to act like a brake, or it will be left open circuit and the bot will coast to a stop.
I dont think you can blow out your victors this way unless you were pushing the bot really fast, and the motors were generating a voltage above the Victors rated MAX voltage spec.
Well they were being spun at the same speeds as the CIM motors running at 12VDC and driving the bot, considerably more power then you can do by hand, and more or less continuously for 1:30 to 2:00 minutes....So it's pretty rough on the circuits. That and we did it four matches in a row
Matt Krass
Unread 23-10-2005, 17:53
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
This may be a silly question:
Have you tried contacting the official Innovation First technical support?
There is an entire forum at www.ifirobotics.com with this purpose in mind.
If nothing else, you will get some feedback from the engineers who actually designed the Victor, as well as those who do a functionality QC check on every product IFI ships.
They may have something for you.
John
Unread 23-10-2005, 18:03
Umm Errr...
Reminds me of the day a couple years ago when we were dusting off our robot with compressed air and we realized that when spun by compressed air, the large kit fan produced enough voltage and current to power up the robot(but not to move anything other than pneumatics). I would not recommend doing this as very high voltages can be produced this way. The lil fans also make a whizzing noise when you blow air over them.... until they promptly die....
1139 Alumni
Unread 23-10-2005, 19:34
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Are you exactly positive what version of the Victor you have? Because they also make a couple of versions which are designed to power rotating objects, and only have a single direction of output.
http://www.ifirobotics.com/victor-sc...r-robots.shtml
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 23-10-2005, 21:19
occra 23.
AKA: ryo
None #1481
unless they specifically bought those they shouldnt have any of those. as they arent in the kit. and didnt he say they had it mounted on the robot and was working till theybackdrove it for a while because they didnt have time to unplug it? or was that a nother person?
Unread 24-10-2005, 00:03
Manoel,
It is possible for you to have checked all the FETs good and still have a problem in reverse. I did come across a few Victors at inspections and other times that did not take the calibration the first or even second time. However in you case since you stated that the LED was coming on in the correct position of the drive , I suspect that the driver for the FETs may be bad. Generally, the FETs short when defective. During operation if no drive is applied and the brake jumper is in the "coast" mode, all FETs are off. If you set the jumper to brake does the Victor actually brake? If so, all the FETs in the low side (that's 6 for those who are counting.) are good. If you do calibration with joysticks and the LEDs go full green and full red, I would contact IFI about repairs. I am sure they would like to find out what died as much as I would.
For the rest of you, the motors back driving a voltage into the robot was covered in another discussion some time ago. Search the archives or I will when I get a chance.
Making a forward only speed control reverse sanddrag Electrical 7 12-12-2003 07:19
What CD's are you looking forward to? Jay W. Chit-Chat 12 31-08-2003 01:39
forward reverse on drill motor PDonovan Motors 2 03-02-2003 11:11
Which teams are you looking forward to their robot? Ken Leung General Forum 17 14-02-2002 19:59
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
