Go to Post "I don't have a cockroach in my presentation.... " I will remember this line forever. Thank you Autodesk. - Zyik [more]
Unread 23-10-2005, 18:37
Umm Errr...
Plants in my Victor?
I was curious about how the victors worked, so i cracked one open and started poking around. The first thing i noticed is that the circuits are coated in some soft of clear silicone-ish substance. Now along with the components there are bits of some sort of bristly plant matter embedded in this coating. They look almost like pine needles only they are too small to be pine needles. Anybody have any idea what this matter could be and what the coating is for? I would theorize that this stuff is some sort of debris that was in the area of the coating as it was curing. This is one of last year's "revision F" victors (according to the silkscreening).
1139 Alumni
Unread 23-10-2005, 20:47
Re: Plants in my Victor?
the coating on the circuits is called conformal coating. Its designed to keep parts from corroding, to make the circuit moisture and sometimes even water proof, to keep foriegn objects from shorting the traces, and its also used in some high vibration / hi acceleration applications to glue the parts to the circuit board
but the pine needles? you may have discovered an instance of spontainious life generation!
Victor and Spike in same circuit? phillutz Electrical 4 18-02-2005 16:57
Victor 884 problem Gal Longin Control System 11 26-01-2005 00:47
Must Connect PWM cable in reverse for victor to work? Leav Electrical 3 12-01-2005 16:43
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
Victor 884 Calibration Incorrect Just3D Electrical 4 15-02-2004 15:20
