Go to Post People were learning left and right. 14-year olds knew what a pitch diameter is... cool stuff. - Andy Baker [more]
Unread 24-10-2005, 20:49
lndnny's Avatar
lndnny lndnny is offline
Does a bit of everything!
None #0808 (Mechanical Mayhem)
lndnny is an unknown quantity at this point
Unhappy Designing a Planetary Wheel (Almost)
I was working on a design of a planetary wheel and the idea blew up! After prototyping it in knex, I realized i was trying to spin something in two directions. I am trying to contain all of the gears in the wheel itself. (about 3 inch wide wheels) Could I please get some help. thanks
Dan Lin
Team 808
Unread 24-10-2005, 20:53
lndnny's Avatar
Re: Designing a Planetary Wheel (Almost)
Ask if you don't understand my concept
dan lin
team 808
Unread 24-10-2005, 20:59
occra 23.
AKA: ryo
None #1481
Dan Lin
Team 808
sorry. dont understand what you are trying to do. a planetary gearbox? or a gearbox within a wheel? the latter i know some team has done. maybe a few. and a plantery gearbox. well i would have to say makeing one will be a pain in the butt but its possible. although i dont understand your trying to spin things in two directions comment... basically for a planetary you need a ring gear, a center "sun" gear and well to make it work well the minimum of 2 "planet" gears. the center of the ring and sun gears should be exactly the same and the planets should be touching both the ring and sun gear.
sorry if im explaining something you already know.. can you be more specific?
Unread 24-10-2005, 21:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Someone else tried to desing one a little while back:
http://www.chiefdelphi.com/forums/sh...lanetary+wheel
and for the most part it was determined that there are a lot of inherent design flaws and it would take an eternity to get the bugs worked out. I'm not saying it won't work, but if you decide to pursue it, be sure you are into it for the long haul. Planetaries can be tricky little things buy themselves, and put all the loads associated with a wheel on one and then you are really asking for it. There are better ways to accomplish the same task.
But don't let me stop you. Who knows, you might discover a big breakthrough in a durable, easy to build planetary wheel.
Oh yes, and there is the "edit" button so you needn't double post.
Unread 24-10-2005, 23:38
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
I don't know if I am missing something obvious, but i cant think of what the advantages of having a planetary wheel would be.
Can someone explain them?
Unread 24-10-2005, 23:45
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
I hope that this adds something to the discussion. I've played with(but never extensively) planetary gear systems . However, I don't understand exactly where the benefit is, could someone explain this? Is it just that it keeps it the outer gear centered? Does it improve performance? Thanks. (This should apply to either the gear or wheel) (Guess this kinda goes w/ the previous post we entered them at the same time)
Unread 25-10-2005, 00:52
CraigHickman
Posts: n/a
Chain weighs quite a bit, so one point of goodness is weight. Another is that it takes up much less space than a "conventional" drive train. I can't personally think of any more positives, but I'm sure there are more...
Unread 25-10-2005, 00:57
The main benefit is lots of reduction in a relatively small space while keeping the output shaft on the same axis as the input. Take for example the globe motor. Do you have any idea how large of a reduction is in that tiny planetary gearhead? Something like 115:1. Try to do that with spurs in that amount of space.
Unread 25-10-2005, 01:12
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
I did something similar in 2004 with swerve drive, having the gear reduction inside the wheel. But I have to ask, why planetary? It costs much less to just use external gears, instead of internal gears. The only thing you dont get anymore with one reduction is the axis of the drive shaft is no longer on the same axis as the wheel. So just use two reductions. I did in the swerve I designed, and it was very spiffy. In fact, people were asking if it had a planetary reduction in it, but it didnt. It was very similar, used a lot less gears, and a lot less bearings. With a reduction of 1:42.
If you look at the link to the concept sanddrag posted, you can tell that the gear reduction in the planetary is just the teeth of the sun gear over the teeth of the internal gear. Why not just make the external gear an internal gear? Solves a lot of problems. But hey, I can understand if you're doing it beacuse its awesome. It is. Having planetary gears reduces the stress on all the gears because more teeth are in contact at the same time. It's a cool idea, I just want you to be aware that it is more costly than several very similar alternatives.
Unread 25-10-2005, 01:25
Isn't it sun/(sun+ring) in a fixed ring planetary?
Unread 25-10-2005, 11:00
calieanZET calieanZET is offline
FRC #1027
calieanZET is an unknown quantity at this point
Originally Posted by patTeam241
...However, I don't understand exactly where the benefit is, could someone explain this? ...
As far as the benefits that planetary gears provide there are several:
1. The loading of the gears is reduced so smaller gears (lighter weight) can be used for the same torque ratings. Instead of having the power transmitted on one side of a gear to one side of another gear, the power is transmitted from several points, reducing the forces at any one point.
2. The overall effectiency of the gear system is greater then chains or belts.
3. The most useful benefit of planetary gears is planetary gears can also provide multiple gear ratios. Depending on which gear (or set of gears) is stationary you get different output speeds. for instance if you have the sun gear as the input, keep the planet gears stationary and the rotation of the ring gear is the output you get one speed. if you hold the ring gear stationary and allow the planet gears to rotate about the sun gear, and use that as the output, you get a different output. If you feed the output of one planetary set, into another planetary set you can have 4 different gear ratios. This method of changing gear ratios has the potential to save weight compared to the more conventional methods because there are no "extra" gears. Most of the multispeed transmissions i have seen at first swap gears in the transmission so that there is always atleast one gear that is not in use, and one that is extra weight not included in the planetary gear system.
4. Planetary gears sets also have the potential to take up less space, then conventional transmissions.
In summary planetary gears do the following:
1. reduce weight
2. increase efficiency
3. able to have multiple speeds
4. decrease size
Unread 25-10-2005, 11:22
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Originally Posted by calieanZET
...2. The overall effectiency of the gear system is greater then chains or belts...
its been discussed on this message board, and the general consensus among the experts is that a single planetary stage's efficiency is usually 90% or less. and while belts usually have a lower efficiency, a properly tensioned and aligned chain can have an efficiency of (up to) 98%.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 25-10-2005, 13:16
College Student
AKA: Pat Cleary
Thanks alot.
Unread 25-10-2005, 14:40
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
On the linked exploded image, the planet gears were fixed, the ring was the wheel and the sun was the input.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 25-10-2005, 15:27
lndnny's Avatar
Thanks for all of these ideas! What I ment when I when I said planetary was what Veselin Kolev was thinking. I'm trying to design a swerve drive and was tight on space and weight. I figured out the problem, two "circular plates" were supposed to be spinning at the same speed, but one was spinning slightly slower. Nothing a little rearranging couldn't fix
Thanks
Team 808
Dan Lin
pic: Planetary...Wheel? Matt Krass Extra Discussion 23 27-06-2005 16:05
pic: Planetary Wheel - Exploded View 4 Matt Krass Extra Discussion 5 23-06-2005 23:56
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
