Go to Post That's some sexy use of aluminium - Bharat Nain [more]
Unread 25-10-2005, 17:35
CBaoth CBaoth is offline
OMG HAX 4 L1FE NOT JUST CHANUKAH!
None #1489 (Fighting Tuna)
Team Role: Student
CBaoth will become famous soon enough
Send a message via AIM to CBaoth
control thingy
ok im sorry if this is wrong forum im new and this looked like best forum.
Ok so our situation is we were downloading a program (this is not related to first its just us messing around///OCCRA) and after program is downloaded the light on thing inside robot (sorry dont know name) for program stayed yellow and the robot wouldnt respond to anything. When we reset same thing. when we turned robot on and off program light started blinking red/green(or orange?) rapidly. We tried tether we tried radio we vacuumed incase of alumium shavings... we have no clue what went wrong does anyone have any ideas?
Sorry if im not cohearant i have problems with writing...
Unread 25-10-2005, 17:51
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: control thingy
Check out page 12 of the IFI FRC Robot Controller Reference Guide for the meaning of the lights.
http://www.ifirobotics.com/docs/rc-r...01-31-2005.pdf
Sounds like a coding problem.
Unread 25-10-2005, 18:03
The Cyborg's Avatar
The Cyborg The Cyborg is offline
That Awkward One
AKA: Mary Soltis
FRC #0051 (Wings of Fire)
The Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant future
Re: control thingy
It sounds to me like the program itself may be faulty. Did you compile the program before downloading to check for any errors?
If it wasn't the default program that is causing this, then I suggest re-downloading the default program back onto the robot.
If it was the default program that did this, then I assume that a glitch was involved in the downloading process, or the Robot Controller (I assume that is what you are talking about) may be faulty. I don't know If this happened to any other teams, but when we first started up a brand new system with a default program on it, it took a little time for the program to get "used to" the controls. But eventually the whole thing started to run without any problems.
I hope this helps.
Sparkie: The little bot(s) that could.
Unread 25-10-2005, 18:29
Team Role: Student
Re: control thingy
if it was error in downloading process how would we fix that cause we tried redownloading and that gave same error
Unread 25-10-2005, 20:54
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: control thingy
As stated by the others, try downloading the default code. The FRC_default.hex file should work.
Unread 20-11-2005, 22:34
Team Role: Student
Re: control thingy
thanks btw now that the thread is answered and compleate is there like a way for the person who created it to lock it?
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Pre-manufactured control box for FIRST Ben.V.293 Technical Discussion 19 22-08-2005 12:53
2005 RadioShack Innovation In Control Award--What Won? Billfred Control System 8 12-06-2005 01:51
2005 RadioShack® Innovation in Control Award! dez250 General Forum 10 10-03-2005 21:29
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
