Go to Post Didn't you know, I can be in two places at once? - Andy Baker [more]
Unread 25-10-2005, 11:30
muy dificil muy dificil is offline
FRC #1611
muy dificil is an unknown quantity at this point
Problems
Has anyone had problems where the GUI cannot find the cmucam2.
Unread 25-10-2005, 12:51
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Problems
I have twice. My problems were caused by a flaky serial cable the first time and the wrong serial port configuration the second. The baud rate was incorrect.
Unread 26-10-2005, 11:09
FRC #1611
Question Re: Problems
Did you ever grab a frame and then the picture became scrambled, and after that the program was no longer able to recognize the camera? That is what happened to ours.
Unread 26-10-2005, 11:37
billbo911's Avatar
Re: Problems
My experience sound somewhat similar. I was trying to learn how to calibrate the camera by following the manual. I would get to the point of grabbing a frame, no problem. Then I would run a color calibration and the next image would come back with an extremely high level of that color washed over the entire image. Almost as though I had placed a colored filter in front of the lens. But on occasion, I would loose connection to the camera. The only way around it was to fully reset the camera. I never really got the thing working to my satisfaction.
I have worked on medical grade imaging systems for 20 years, all of it with pick-up tubes, except for the last three years when I began using CCD cameras and Digital Flat Panel detectors. My experience with CCD's is quite limited, but from the little I have had, nothing I've used behaved anything like this. Now, I have to admit, the camera systems I worked on cost between $25K and $35K. So, there really is no comparing the two.
I would love to hear from teams that actually got the camera working as advertised and hear what they did to get the system working.
Unread 26-10-2005, 16:39
foobert foobert is offline
foobert is a jewel in the roughfoobert is a jewel in the roughfoobert is a jewel in the rough
Re: Problems
not sure how much of a difference it makes, but the cmucams use a cmos sensor rather than a ccd.
Unread 26-10-2005, 17:10
billbo911's Avatar
Re: Problems
Well, my day is complete, I learned something new. Can I go home now?
You're right, I was not aware of that and I agree, it doesn't make all that much difference.
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
Robot Rodeo - fixing control problems Gary Dillard Off-Season Events 7 26-10-2004 00:46
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Radio problems -- not archiver 2000 1 23-06-2002 22:23
