Go to Post If you look closer, you'll see I did those photos over a period of years... and they were only done with one program... but yeah, a little free time with no where to direct it and I can become, um, creative... - MissInformation [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 26-10-2005, 22:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Getting PocketPC audio to play on truck's speakers
I sometimes use my PocketPC and bluetooth GPS receiver to give me directions while I'm driving. The problem is though I don't like having to take my eyes off the road to look at the screen, and the road noise in my truck is so loud that I can hardly hear the directions that is gives out over the tiny little built in speaker. And I don't want to drive with an earpiece. So, I want it to play the directions on my truck's factory audio system.
I've seen those things that you plug into the headphone jack that broadcast a radio signal and that seems like a pretty good solution for the price but there's another problem with that. I'd have to change radio stations to hear it. I like listening to the radio while I drive, and I don't really want to have to switch stations to hear the GPS because I might be on my music station while the GPS is saying something important on its own station.
So, what I need to be able to do is have the PocketPC interrupt whatever is playing on the truck's factory audio system, and "speak" the directions, then resume whatever I was listening to when it is done "speaking"
Is there any possible way to do this? It is a Dell Axim X30 PocketPC with integrated bluetooth running Windows Mobile 2003 and it is a 1999 Ford ranger xlt with the "premium" factory audio system.
Thanks.
EDIT: To answer the below question: it is the Navteq gps system.
Unread 26-10-2005, 22:25
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: Getting PocketPC audio to play on truck's speakers
Thanks.
I've thought about this a lot myself, as I have the same problem. It just never got annoying enough that I bothered to really spend some time working on it.
The easiest way would just be to get a bigger speaker to run the pocketpc on, as it would be a pretty significant task to interface with the truck's sound system. Specifically the premium systems often use external amplifiers. (Although external amps might be better, as you have a better chance of wiring something into the preamped signal, but bad as its more difficult to figure the system out). Some stereo systems support a cell phone mute function, where it will mute it when something activates that line. You could use a comparator on 1 chan of the audio line with a ~300mV (just sort of guessing at that, you might have to adjust it, I think a line out is approx. 1V) reference to trigger that if you wanted. (As it should be over that if there is something coming out the output of the X30).
On a side note, what software do you use with it? I too have an X30 and use it with my bluetooth GPS - I'm currently using TomTom Navigator 5, but I used iGuidance before and didn't really care for it. TomTom has its issues as well, though.
any more triple play songs? xzvrw2 Chit-Chat 5 09-04-2005 18:48
