Go to Post So please, think twice before you click that little button that says "reply". - Ken Leung [more]
Unread 27-10-2005, 12:25
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Help me raise amplify some speakers
A while back I bought this toy from Discovery because it advertised that it could make your voice sound like a robot. Well I wasn't expecting a miracle and actually when I tested it it did kind of have a cylonish sound to it. The big problem is that it's very quite and I was hoping to mount it into our mascot's costume. I did what any FIRSTer would do, I dismantled it to see if I could get it to do what I wanted it to. I assume ill be using a amplifier to boost the signal from the speakers but I can't find any that are really appropriate for this task. Any help would be appreciated. Thanks all
Unread 27-10-2005, 12:40
Re: Help me raise amplify some speakers
how much power do you want, and what power source do you want to use (what supply voltage?)
Unread 27-10-2005, 12:46
Ah yes completely forgot. Well if I do use a amplifier it would be powered separately. I'm thinking 9-12 volt would be possible since this has to be wearable.
Unread 27-10-2005, 13:06
check digikey.com - the universal supplier for all things electrical
you should be able to find a single chip, single supply power amp that will put out .5 to 1 W easily, that will run off a 9V battery
Unread 27-10-2005, 21:46
Radio Shack has a prebuilt speaker amp that runs on a 9v battery. (At least they used to) Check www.mcminone.com for kit amps. The problem you will face with this device is feedback to the mic input. The speaker should have a decent output as it is but there are two problems you might be encountering. First, is there a headphone jack? If so, it may be intermittent and needs some contact cleaner and exercise. The second is the speaker, these do make a much higher output when they are in a box, or "infinite baffle". With nothing surrounding the driver, the out of phase back radiation is mixing with the front.
What did this come out of? It is possible that the signal routed out to another spot on the device and all you need to do is add a jumper to route to the speaker amp.
Any videos of First Frenzy Raise the Bar??? chaoticprout General Forum 2 04-11-2004 01:51
pic: Barring the Raise CD47-Bot Extra Discussion 5 20-06-2004 23:46
Do you think FIRST will ever raise the Entrance Fee? team222badbrad General Forum 6 25-04-2003 07:18
How much do you need to raise? roninmedia Fundraising 3 30-03-2003 18:09
$$$ How much do your students need to raise? Please respond!!! archiver 1999 7 23-06-2002 23:03
