Go to Post Simply. Minimize. Reduce. It's a good engineering rule, and an even better management one. - Tom Line [more]
Unread 27-10-2005, 20:31
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Question Re: If you could change one rule - eliminate ship requirement discussion
FIRST Q&A is down so I wanted to double check this. Capacitors are in fact illegal right? Are they considered an alternate power source?
Unread 27-10-2005, 23:28
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: Are Capacitors Legal?
I can't speak for the 2006 rules, but in the 2005 rules, as far as I can tell, capacitors are legal if they are not used as a power source (i.e. they follow all the rules pertaining to custom circuits). You should be fine using them in an RC filter circuit in custom electronics.
Zan Hecht
Unread 27-10-2005, 23:43
Great I have a 54 Farad capacitor bank I wanted to use and I didn't want to go buy a couple and have it be illegal. I think on second thought though ill wait until kickoff to see what Dave Lavery pull out of his sleeve this year. I'm looking forward to it.
Unread 28-10-2005, 00:02
ahecht's Avatar
'Luzer'
AKA: Zan
As per the custom circuit rules, you could use that capacitor bank, but you could never use that stored power on any sort of output device. In fact, the output has to be connected to the analog inputs, digital I/O, TTL Serial Port, or Program Port. So, if you want to use your bank to fry your RC, nothing is stopping you (well, except for the hazardous devices rules).
EDIT: A 54 farad bank would probably violate the cost limits as well.
Zan Hecht
Unread 28-10-2005, 00:26
Umm Errr...
I assume you mean using a capacitor just like you would in a car stereo install. This usage is in fact illegal.
54 farad capacitor!!!!! Thats just scary.
1139 Alumni
Unread 28-10-2005, 00:35
Ok, then ill use then in one of my own robotics projects as a battery replacement. Yeah they are 1.1 pound 54 farad capacitor banks with auto balancing software. They are a brand of ultracapacitors made by maxwell. http://www.maxwell.com/ultracapacito...s/modules.html
Unread 28-10-2005, 01:20
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
To add insult to injury, you would have to start the match with the capacitor discharged, per <R02>.
Unread 28-10-2005, 03:08
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
What are those things supposed to be used for!? What could you possibly do with a 430F cap at only 16V? They also have a 2.6kF for 2.5V. I couldn't find any price info though.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 28-10-2005, 07:24
Capacitors are not strictly illegal but they cannot be used for power filtering at the power input to the RC. As an inspector I would also need to see a valid method for discharging the capacitors at the end of the match. Something automatic and absolutely fool proof. Barring that, everything must be insulated.
Remember there is a lot of power locked up in a 54 Farad capacitor. Certainly enough to weld metal if it were to come in contact with something.
Unread 28-10-2005, 10:20
I wanted to use it in conjunction with a CIM (before the speed controller). I couldn't find a rule that would flag it (I'm not sure the alternate power source rule would apply) but it would probably get flagged anyway. Yeah I know that 54 Farads is a lot but consider the power draw on a single CIM. These in particular are used as replacements for batteries. I might use it in an off season project to see what effect they have on the motors.
Unread 28-10-2005, 11:16
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
A capacitor would be considered a custom circuit, subject to the custom electronics rules. Right off the bat, it would be in violation of these two rules from 2005:
Originally Posted by 2005 Manual, R51
All outputs from the custom circuits must be connected to the analog inputs, digital I/O, TTL Serial Port, or Program Port on the Robot Controller.
Originally Posted by 2005 Manual, R53
Custom Circuits may not: Directly affect any output devices on the robot, such as by providing power directly to a motor, supplying a PWM signal to a speed controller or supplying a control signal to a relay module. (Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the robot’s electrical system is acceptable, because the effect on the robot outputs should be inconsequential.)
Unread 28-10-2005, 13:01
Yeah, what Dave said! (Thanks Dave)
In that application it would be more of hindurance than you think.
That calculates out to 3888 Joules and by my guess would take almost 16 seconds to charge up during which it will look like a dead short across the battery for most of that. I calculate 240 amps will flow into the capacitor at the begninning of the charge cycle.
Unread 28-10-2005, 15:59
Yeah your right it violates the first one but the second one? It is not providing power directly to the motor but through the victor. But the point is mute since it violates the first rule. Oh well this is starting to look better suited for a private robot. Just another idea I had been throwing around. Oh Mr. Skierkiewicz could I possibly power the capacitors seperately and then apply power to motors? Maybe with a second connection and a switch to apply a physical connection (A switch would also allow my to disengage the capacitors from the motor if needed)?
Unread 28-10-2005, 17:04
what is the price and weight of one of those units, and what exactly do you expect it to do for you on the robot?
The batteries supplied in the kit are able to put out 200 to 300 amp surges - I think if you pumped any more current through a Victor or through the motor you would see a cloud of smoke where your robot use to be!
What problem are you attempting to solve by adding these to the bot?
Unread 28-10-2005, 17:06
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
I would also think that it would be a safety issue. If someone touched that capacitor at the terminals it could seriously injure them. Also I don't think capacitors that big can handle that much vibration, which would make them impractical to use.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
