Go to Post If you are stupid about this and violate the rules, and thereby cause your alliance to lose a match, then your alliance partners will gang up on you and violate your robot. - dlavery [more]
Unread 21-10-2005, 10:56
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
Cutting
I was wondering on how to cut an assembly part in Autodesk Inventor. I am just trying to cut a bumper in the kit of parts.
Unread 21-10-2005, 14:22
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
Re: Cutting
I don't have the program in front of me, but i believe that if you place a plane in the assy where you want the cut to be made, and then use the slice (i think) command form either the side bar or the menus and select the plane that you just created as the slice plane.
Hopefully that helps.
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 23-10-2005, 00:18
JasJ002's Avatar
JasJ002 JasJ002 is offline
Inventor Freak
AKA: Jay
FRC #0662 (Cybersonics)
JasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the rough
Send a message via AIM to JasJ002
Talking Re: Cutting
by cut do you mean split a part in half or completely dispose of half of your bumper?
2005 2006 2007 Autodesk Inventor Winner
2005 Winning Site & 2006 Winning Site
2007 Winning Site
Unread 23-10-2005, 01:06
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Cutting
Cuts are usually done on a part by part basis. If you wanted to remove some shape from your part, you would create a sketch of what you want to remove and when extruding/revolving/whatever you use, choose subtract from the menu (might also be called remove, cut, but is one of the three buttons that control how it extrudes). If you want to cut off a portion, I would recomend the slice tool. You create a work plane, or some other plane, that you will cut along. The slice tool looks like a part that suddenly ends at a yellow work plane. You select the plane and the part. you might have to experiment on which way you want to keep, but is mostly common sence. You might be able to pull of a similer action on a complete assembly, but I doubt it. This stims from the fact that it is referencing the parts and would find it hard to cut though one version of the part and not another.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 25-10-2005, 15:00
AKA: Keegan
FRC #0414
Re: Cutting
Originally Posted by jdiwnab
... You might be able to pull of a similer action on a complete assembly, but I doubt it. ...
I have done this in an assy, but it is much easier to either select the part in the assy to work on and then slice, or to jsut go back to the part itself.
Sweet!
- Nikola Tesla
- Samuel Butler
Unread 26-10-2005, 00:46
CraigHickman
Posts: n/a
Re: Cutting
Just right click on the part, and click edit. From there, do your work. Then go to Return, up at the top, and it'll go back into the assembly.
Unread 28-10-2005, 10:35
Re: Cutting
Thanks that works great.
YMTC: Can teams start cutting metal for 2005? Natchez You Make The Call 67 07-02-2006 21:55
Water Cutting in Detroit Jack Jones General Forum 0 09-03-2004 03:02
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
Victors for Chips Cutting Off aaronbr28040 Control System 13 20-02-2004 16:52
