Go to Post The day I walk down the street and overhear a conversation like "Hey, did you check out Andy's new gearbox design yet?" ... - Aignam [more]
Unread 28-10-2005, 21:35
Andrew Blair's Avatar
FRC #0306 (CRT)
Embossing Text Into Parts with Inventor
What I would like to do is cut a "306 CRT" out of sheet metal assemblies we have have cut. My problem is twofold. First off, when I put text onto a drawing, I can't cut it from the piece. So, I can just trace the letters, but I really don't want to have to do this on every single piece. Is there some way I can easily cut text from a drawing?
-Sir Francis Bacon
-Albert Einstein
Unread 29-10-2005, 09:04
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
Re: Inserting Something Into Inventor
There should be an emboss tool you can use. This should allow you to basically cut or extrude text. Hope this helps!
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 29-10-2005, 15:13
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Exactly. You can emboss text onto or out of a part using this tool. You create a sketch on the surface you want to emboss (or on a work plane), use the sketch text tool to create the text, finish the sketch, select the Emboss tool and select your text for the profile. See Inventor help for more detail on how to emboss.
To make real parts you'll need CNC, and you'll lose the islands in the letters (like the center of "0"), unless you add bridges.
Pete Kieselbach
Unread 29-10-2005, 23:41
FRC #0306 (CRT)
Hey, thanks guys! I guess I never payed attention to the fact that the emboss icon had an embossed letter on it... not having inventor handy on me right now, can you get different text fonts, say some with bridges in already?
-Sir Francis Bacon
-Albert Einstein
Unread 30-10-2005, 12:47
petek's Avatar
What would Dave do?
I'm pretty sure Inventor uses Windows' fonts and I don't think there is a stencil font in the standard ones, but you could install one (I don't have any experience with this particular one).
Pete Kieselbach
FRC 2005 Drivetrain and Transmission Parts on Autodesk Inventor 7 KrazyRoadster Inventor 1 23-01-2005 20:29
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Inventor text 157#1Driver Inventor 1 22-02-2003 17:38
Inventor drawings of parts from kit patrickrd Inventor 1 11-01-2002 14:16
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
