Go to Post A good leader will step down so the right people are in the leadership positions, regardless of age. - Phoenix Spud [more]
Unread 30-10-2005, 09:51
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
Speed Videos
I was wondering if anyone knew of videos that show the capabilities of a VEX Robot. I've seen videos of it doing random things, but I'm looking for a video of a VEX Robot going from one end of the field to another.
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
Unread 30-10-2005, 14:40
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Speed Videos
What type of bot are you talking about? Just a standard "square-bot", as provided in the Vex starter kit? One of the FVC bots from last year? A custom-bot built for speed (cough cough"speedy-McLavery" cough cough)?
Unread 30-10-2005, 19:02
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Speed Videos
If you are looking for videos of last year's FVC robots, check out the videos page on VexLabs. But you can find the speed of a Vex robot without needing a video of a robot, simply by using a few simple formulas. Ahh, behold the power of mathmatics.
The Vex motors spin at roughly 90-100 rpm. On the Squarebot, there is a 60 tooth input gear on the motor, and 36 tooth output gears on the wheel axles. Use the formula r1•t1 = r2•t2. The r1 is equal to the rpm of the one gear, while r2 is equal to the rpm of the other gear. The t1 is equal to the teeth of the first gear, and t2 is equal to the teeth of the second gear. You need to know only three of these variables to find the fourth. You know the number of teeth of the two gears, and the rpm of one side. Using the formula above, we get:
100rpm•60t = r2•36t
When we solve this, we get 166.66 rpm for r2. But we're not done yet! To find the speed of the robot, we need to know the size of the wheels. The Squarebot uses the small 2.75 inch wheels. Using the formula C = π•d, we can find exactly how far the wheel travels in one revolution. The circumference of the 2.75 inch wheel is 8.64 inches. Multiply 8.64 inches times 166.66 rpm and we get 1439.94 inches, which equals 120 feet. This is how far the robot will travel in a minute. To find how far the Vex robot will travel in one second, divide this by 60 to get 24 inches (2 feet) per second.
Enough math for now...
This is a good rough estimate. Of course, the weight of the robot, the gear mesh efficiencies, etc. will lower this final outcome. But to put this into contrext, the 2006 FVC field is 10' x 14'. Assuming the Squarebot can travel up and down the ramps at the same speed as it travels across flat ground, it would take 7 seconds to drive across the 14 foot length of the field. You can experiment with different size wheels and gear ratios and use these formulas to find the speed of the robot. Just remember, you cannot gear the output wheels too fast or the robot won't move at all because of speed and torque are inversly related. But that is for another day...
Art Dutra IV
世上无难事,只怕有心人.
Unread 31-10-2005, 11:41
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Re: Speed Videos
This might help a little:
http://www.vexlabs.com/forum/viewtopic.php?p=195#195
Unread 31-10-2005, 15:32
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Re: Speed Videos
Thanks i think i got the info i needed
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
videos needed archiver 1999 3 23-06-2002 22:09
