Go to Post Maybe FIRST will just take 148's Tumbleweed and use it as the game piece for next year. - AndyB [more]
Unread 30-10-2005, 16:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Post Coders' Wishlists for 2006
Seeing as it's getting closer to the kick-off, and everyone's gearing up for the next season, I'd thought I'd ask what everyone would like to see change as far as programming goes.
Here's mine:
  • More memory
  • Trig
  • Use Eclipse right out of the box
  • Open source dashboard, loader, & dev reader
Unread 30-10-2005, 17:55
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Coders' Wishlists for 2006
Hey, even as a an amatuer programmer, more speed! It would be nice to be able to to more intensive math without crashing the control code. And maybe hardware enabled floating point.
-Sir Francis Bacon
-Albert Einstein
Unread 30-10-2005, 18:03
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Only thing I want is a longer autonomous period and more sensors in the KOP. I like the current controllers though it would be nice if the compiler worked natively on Linux.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 30-10-2005, 18:27
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
I really like the open source dashboard.
One can always use small, cheap Parallax or Microchip controllers for sensor input/computation, and not worry about using the main RC for that.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 30-10-2005, 18:38
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Originally Posted by Astronouth7303
  • Trig
Version 3.9, I believe, of the mcc18 compiler has that, just include <math.h>
EDIT: I'm going to wish for more program space. I have a feeling the project I'm working on is going to take up a good amount between autonomous code, user-driven code, serial communication code, eeprom code, etc.
http://www.mikesorrenti.com/
Unread 30-10-2005, 18:52
Umm Errr...
Its been a while since have though about FRC code but:
I doubt they are going to make any hardware changes but i am going to wish for a 16bit PIC anyway.
Access to at least 1 whole set of GPIO pins would be great
In addition, i think the base code could use some radical changes in the way of abstraction and modulalarity. We probably rewrote 60% of it last year.
More memory. FLASH, RAM. There are a number of pics that would be almost drop in replacements that would meet this criteria.
1139 Alumni
Unread 30-10-2005, 19:42
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Here's mine:
  • More memory
  • Trig
What kind of trigonometric functions are you looking for?
-Kevin
Kevin Watson
http://kevin.org
Unread 30-10-2005, 20:59
I'd like to see more of an event-driven framework, or at least something that doesn't look like autonomous mode is an afterthought.
And I'd really like to see the limit_mix() function die.
Unread 31-10-2005, 00:20
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
-Kevin
Maybe there can be an implementation of a fixed-point set of basic trig functions that can be used. I know there are fixed-point approximations for some trig fucntions that work fairly well and don't require a large lookup table.
Matt
Unread 31-10-2005, 00:29
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
No more MPLAB.
Give us support for something else.... anything else... just no more MPLAB.
Which badges can you claim?
Unread 31-10-2005, 00:48
FRC #2429
Matt
I've written some code that that will do fixed-point sin() and cos() using an EEPROM look-up table. One piece of code is executed once to create the table, another body of code is used to do fast look-up. Once I write the documentation, I'll release to code for folks to try out.
-Kevin
Kevin Watson
http://kevin.org
Unread 31-10-2005, 09:01
jazzsaxman1988's Avatar
jazzsaxman1988 jazzsaxman1988 is offline
AKA: Hal
#0404 (Distant Rage)
jazzsaxman1988 is an unknown quantity at this point
Send a message via AIM to jazzsaxman1988 Send a message via MSN to jazzsaxman1988 Send a message via Yahoo to jazzsaxman1988
Originally Posted by Redneck
No more MPLAB.
Amen... MPLAB should die. It'd be nice if we could set up a project in Visual Studio to handle it
So he was standing there, surrounded by sinners, blasphemers, and the devil himself, and he thought to himself, "Well, no one's perfect..."
Unread 31-10-2005, 14:57
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Well, there is support for other things thanks to the work of others. Search for "using eclipse."
What I would like to see:
  • Much more organized default code. Sure, you can take the stuff they give you and fix it, but then when they change a few things next year you have to start all over. One easy thing which would be especially nice for newer programmers would be just move all the utility include files into a separate directory. (Leave things that people commonly want to edit in the main area.)
  • Stripped down version of the default code. A version of the default code which contained only the essential, basic structure would be handy for the more advanced teams. Continue to have a version with examples, but also make one which gets rid of things like the default mappings of the joysticks to the motors.
  • USB programming capabilities. Yeah, I know that USB to serial converts usually work, but driver for the one I got caused horrible stability issues on my Windows box (not to mention took 10 minutes to download...) and it doesn't work at all with my Linux laptop. (As a side note: if anyone knows of one that works with Linux, tell me please!) I realize that the hardware isn't likely to change for a few more years, but is a wishlist.
  • Going off of that, native support for Linux would be nice. Not a big priority thanks the work of many people on this forum, but what if the next version of the compiler breaks all their work?
Last edited by Ryan M. : 31-10-2005 at 19:00. Reason: I lied... it's not in his sig.
Unread 31-10-2005, 16:02
-Kevin
I had some similiar code last year but it got lost in a laptop crash. There's also a pretty good atan2 approximation (or at least it seemed to be) out there if you'd want to include that too. This is what I based my implementation on last year: http://www.dspguru.com/comp.dsp/tricks/alg/fxdatan2.htm
Matt
Unread 31-10-2005, 17:52
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
No more MPLAB.
Couldn't agree more.
I'd also like a USB programming port for the FRC. Not many laptops have serial ports anymore and in any case USB would be much faster. Oh yeah, we need to have the IFI loader have a large (infinate) buffer for the printfs.
I don't really care about the code FIRST gives us as producing code is my job. Other than that I want more code/variable space so that we can have better, more overly complicated autonomous modes.
Behold the power of SPAM.
