Go to Post For example, you can make a car as safe as possible. It may get the highest safety ratings in it's class, but if you drive it off of a cliff there really isn't much you can do about that. - jmanela [more]
Unread 01-11-2005, 04:03
BorisTheBlade's Avatar
BorisTheBlade BorisTheBlade is offline
lead programmer 2004
AKA: Dane
FRC #1351 (TKO)
BorisTheBlade has a spectacular aura aboutBorisTheBlade has a spectacular aura aboutBorisTheBlade has a spectacular aura about
Send a message via AIM to BorisTheBlade
programming motors with programming kit
just curious I must be doing something wrong or something but I'm trying to teach our new members how to program and I tried just going into the default routine and just setting the motor to full forward like this:
pwm01 = 255;
then when I download it it does nothing is this not the way to do it anymore? Back when I was using the EDU bot 2 years ago this always worked just fine. could really use some help on this one. thanks
Team 1351 TKO Robotics (click for our website)
2007 sacramento regional Johnson & Johnson Sportsmanship Award winners
2007 CAL Games Finalists
Unread 01-11-2005, 10:23
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: programming motors with programming kit
Originally Posted by BorisTheBlade
... I tried just going into the default routine and just setting the motor to full forward like this:
pwm01 = 255;
I was unable to get of my own code to work until I changed one particular section. This is in the "user_routines.c" near line 193.
In the following code, you define who controls the PWM, the USER or the MASTER PIC. You will have to write the code for generating PWMs if you want the USER to to control them. ( For seriously custom code )
/* SEVENTH: Choose which processor will control which PWM outputs. */
  //Setup_Who_Controls_Pwms(MASTER,MASTER,MASTER,MASTER,MASTER,MASTER,MASTER,MASTER);
  Setup_Who_Controls_Pwms(USER,USER,USER,USER,USER,USER,USER,USER);
If you have not changed this, the USER will be controlling the PWMs and your code will not. Change these lines according to what you want to control and your code should work.
Unread 01-11-2005, 16:44
AKA: Dane
FRC #1351 (TKO)
cool thanks alot I'll give it a try!
Unread 01-11-2005, 18:41
Morenoh149
Posts: n/a
just clearing up. Is this right?
/* SEVENTH ...
Setup_Who_Controls_Pwms(USER,USER,USER,USER,USER,U SER,USER,USER);
Unread 01-11-2005, 19:03
billbo911's Avatar
I'm working from memory here, I won't bet my pay check on what I am about to say, but I believe I am correct.
You will need to set that line to:
This will cause the master processor to handle the PWM signal generation. If left at the value from the default code:
then the user processor would have to generate the PWM signals. This means that you have to write the code yourself that will tell the user processor how PWMs should be created.
BTW, If I'm not mistaken, this line will also allow you to mix both USER and MASTER for the various PWM outputs. Thereby, having complete control over certain PWMs while allowing the master processor control the output of others.
Programming Vex Starter Kit To Recieve From Serial Port firetrap FIRST Tech Challenge 0 26-09-2005 17:27
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
