Go to Post (Water on all this would be good too) - buildmaster5000 [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 01-11-2005, 00:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Forcing a Cable Modem to get a new IP
I want my cable modem to get a new (global) IP. How do I do it? Charter Broadband cable service. It is not static, but it almost never changes. Even a long period of having it powered off will not change it. Surfboard cable modem and a router. Thanks.
Unread 01-11-2005, 00:20
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: Forcing a Cable Modem to get a new IP
It might not be possible. It's assigned on your ISP's end. I've noticed the same thing with my SBC DSL modem though. I only get a new IP every month or so. My guess is that the IPs are assigned to the modem for long periods.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 01-11-2005, 09:06
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Try changing the MAC address of your router (most have a spoofing feature), and then changing it back. It will almost definitely change when you change it the first time, but I'm not sure if you will get the same one when you change it back.
Unread 01-11-2005, 10:44
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
You can try leaving it off for a day or two. That usually works with most ISPs, but you have to survive without the internet for that time.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 01-11-2005, 11:27
The cable providers allocate IP address using DHCP. It looks at the MAC address of the computer (or router) it is communicating with and goes from there.
So,
1) Unplug your cable modem for about a minute
2) Direct connect your PC or laptop to the modem
3) Power On Cable Modem (on surfboard, wait for the "Online" light to come on constantly)
4) Wait another minute.
5) Repeat steps 1-3 for Router.
Unread 01-11-2005, 11:51
Here's what I did:
Unplugged cable modem power and unpluged it from router.
Powered on PC and plugged it directly into cable modem.
Plugged in cable modem power and waited for it to come fully online.
Unplugged PC and plugged router back into the cable modem.
Is this right or did I do something wrong? It didn't work. Perhaps there is an IP assigned to the modem for a very long period of time?
Unread 01-11-2005, 14:21
Why?
My Earthlink modem will get a new IP everytime I reconnect or my lease runs out. It really doesn't matter what it is if you are connected. The IP that the cable or DSL sees (from the modem) is not the same IP that your computer or network see from the other side ( the network output).
Unread 01-11-2005, 14:34
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Originally Posted by Al Skierkiewicz
Why?
Sometimes it's useful if you've been playing an online game and some guy with a thing against you decides that a ping flood would be fun. If you change your IP, he doesn't know where you've gone. Well, that's never happened to me, but it's definetly possible.
Try going into your router's config/admin page (typically 192.168.1.1 or .254. Check in your manual.) and finding the release and/or renew option. On my Hawking wireless router, it's on the "status" page, but on an older one it was under "advanced configuration." Look around.
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Cable modems have their own built in MAC address, besides passing on the MAC of the associated computer or router. That's how cable companies keep track of who is using their network (unlike DSL which relies on authentication via PPPoE.)
Sanddrag, DHCP servers assign IP addresses with a set lease time, sometimes 3 days, sometimes 7 days, depending on how the network is set up. Most of the time, the release and renewal when an IP expires is transparent, it happens in milliseconds and there's rarely a disruption of service. The problem you're having is most DHCP servers cache MAC addresses in a client table, and tend to assign the same IP associated with a given MAC address each renewal. Network operators and their servers appreciate consistency, and on a network with potentially thousands of clients, the more consistent addresses are, the less stress there is on the server to straighten out the client table and make sure everyone gets an address. Rather than try finding the next available address for your system, it remembers you had that address last renewal, and gives it back to you.
Only way around that (short of calling your ISP directly and asking if they can clear your MAC out of the client table) is to find out how long your IP lease is, and unplug your cable modem an hour before the lease expires, and plug it back in an hour after the lease expires. If your modem isn't online to negotiate the renewal, the DHCP server should chop it out of the client table and assign the IP to another client. Next time your modem communicates with the DHCP server, it should assign the next available IP in it's block. Generally, the longer you wait after the expiration, the better chance you'll have to get a new IP (the assumption is another client will come online to take your old IP before you do).
Unread 01-11-2005, 14:57
FRC #0190
When you plugged it directly into your laptop, did you get the same IP as your router did?
If you got a different IP on the laptop, but the same one back on the router, spoof the router to a MAC address of a network card you own. (As this is more legit than making one up that is assigned to someone else, and as long as that network card is always on the LAN side of your router, it shouldn't cause any issues).
Usually the modem's MAC address is used to assign it a non-internet (private) IP in the 10.x range, and the MAC address of the client PC is used to assign the internet IP. I'm not familiar with the CMTS system that Charter uses, however, so it may be different.
Unread 01-11-2005, 16:02
I believe you hit it on the money. I'm pretty sure this is how charter works. So how do I find out when the lease expires? Is it on the surfboard status page? The reason I need to change is that my IP is blocked from a (computer) site and there is no reason it should be.
Unread 01-11-2005, 16:04
Use a proxy.
Unread 02-11-2005, 01:01
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Using a proxy server works fairly well to get onto a website that you're blocked from, I had someone on another team whom blocked the team's website from my IP address ( which is static being its sDSL). I logged onto one of my proxyservers and logged on and emailed him and suddenly I was unblocked the next day. So maybe log on and email the site admin and see whats up.
-Mike
Unread 02-11-2005, 06:10
Bharat Nain's Avatar
Marc said it all right. I needed to get my IP changed so I called up my ISP and told them. It took them 10 minutes to reset it.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
2 questions about LAN (10/100) cable. Elgin Clock IT / Communications 19 16-11-2004 12:04
Breaking Cable WebWader125 Technical Discussion 13 28-05-2004 16:44
Fun Times at the Hardware Store sanddrag General Forum 10 19-03-2004 23:55
LEGO IR tower cable Jeff Rodriguez Chit-Chat 1 31-10-2003 16:23
Competition port cable Ken Leung Electrical 2 17-09-2003 08:12
