Go to Post These awards aren't easy to get, and if a team deserves an award, they deserve to be cheered on for it. - tckma [more]
Unread 01-11-2005, 21:52
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
pic: Lego Robot for a F.I.R.S.T.-ish Game
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 01-11-2005, 21:56
occra 23.
AKA: ryo
None #1481
Re: pic: Lego Robot for a F.I.R.S.T.-ish Game
i highly reccomend shortening your wheelbase or widening the track or using less grippy tires. you would have trouble turning iwth that setup. and i highly reccomend you learning how to use "Reinforcements" to make a stronger. more reliable robot with less weight. beam on beam on plate only works for so long.
and as for max amps from a rcx, do keep in mind its possible to use battery boxes and use an rcx to change the switches. doesnt drain the rcx batteries as fast either. have fun!
Unread 01-11-2005, 22:15
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
If the current setup does not turn as effeciantly as I would like it to with all of the final weight I am just going to take off the front tires rubber gripand be left with only the white hub touching the ground. I have already dabbled in this area and have no worries about it. Right now, I have a simple mock up on the front of the robot for lateral stabilization, it makes it easier to work on the base of the arm that way. When the final bot comes out it will not move wobbled/flex/ anything. I am going to build it like a true 222 machine; so I should be able to drop it from 8 feet in the air . The weight is no issue. Right now I am actually planning to add weight blocks for a counter balance, but this is one of those test it when it is done things.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 01-11-2005, 23:48
Scott team 48's Avatar
Scott team 48 Scott team 48 is offline
FRC #0048 (Delphi E.L.I.T.E.)
Scott team 48 is a jewel in the roughScott team 48 is a jewel in the roughScott team 48 is a jewel in the rough
Send a message via AIM to Scott team 48
Also something you want to consider is if you want to run all of the motors independantly is that each rcx has 4 outputs, my idea of how ur planning on doing it would either require that second rcx, or run your brush off one of your other motor outputs, but that limits it a little bit, you probably knew all of this tho, just thought I'd make sure you did.
Delphi Elite
Unread 02-11-2005, 16:54
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
Each RCX only has 3 outputs actually. The only way I have figured yet of powering all of my motors is to put output in parallel from the CXs and run a single wire carrying the voltage for motors with the same task and re split the wires down at the bot to go the the individual motors. I think I am going ot use 2 homemade lego joysticks and push button limits for alll of the actual driving.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 02-11-2005, 17:04
If you want two motors to run at the same time all the time, try putting them both on the same output port. If that doesn't work, then link two RCX units somehow.
Unread 02-11-2005, 17:13
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
That will work I just want to make sure that I am getting the most power posssible to these motors which is why I am going to double outputs and then share inputs between the two (maybe three [hehehehe]) RCXs.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 02-11-2005, 19:34
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Thats amazing. My team is really behind right now. But, they have a GREAT mentor (Mat Temme) and I believe they can get it done in time. (I can't help with programming, I help make the mechanical parts) Will this bot be at a FLL comp?
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 02-11-2005, 21:31
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
This robot will be competing in Robot Ramble, an event in Science Olympiad.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 02-11-2005, 23:16
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
[off topic] You own the game pit! that is awesome! [/off topic]
Looks cool man, good luck in competition.
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
Online Game and Robot Quiz Metalhugginman General Forum 11 13-02-2004 14:21
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
