Go to Post Mentor-built (adj.): A term describing a robot that is better than your own, and / or a robot with paint on it. - Chris is me [more]
Unread 03-11-2005, 01:27
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Additional field coils around motors
I know everyone always wants more power form their motors, and that we aren't supposed to open them up to mess with them, but if you were to wind additional coils around the motor, could you increase the field strength legally?
I was thinking something along the lines of a series wound or shunt wound coil at first, but those are for AC electric motors, and only go in one direction.
However, if you were to have the field coil on its own speed controller, you could vary the strength of the field for when you need it.
This would be considered a custom circuit, so reading R52 from 2005
Inputs to custom circuits may be connected to the following sources:
Branch Circuit breaker outputs
Speed Controller or Relay module outputs
PWM or Relay outputs on the Robot Controller
Switches, Potentiometers, the outputs from Accelerometers, Sensors, and other additional electronics allowed
So it would be legal to have the inputs of this circuit (the power inputs) connected to a Victor, at least as how I see it.
So it would be setup so that once you hit full power on the motors, you start powering up the field coils around the motor to increase the strength of the motors.
Granted it wouldn't be that easy to wind the coil so that it's field matched that of the CIM, and there already is so much power available, and current draw is allready pretty high. Would it be legal, and beneficial to make a setup like this? Maybe as a big red button for when your in a shoving match or something.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 03-11-2005, 01:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Additional field coils around motors
What about just putting a steel band around it like the fisher price motor has?
Unread 03-11-2005, 04:39
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Take another look at <R31> - What part of "So that every robot’s maximum power level is the same," don't you understand?
Unread 03-11-2005, 09:01
Team Alumni
Yes it says that, but looking at it in context it says after that "the motors in the kit may not be modified except as follows" and the purpose of this would be to do that without modifying the motors.
Sanddrag- Yeah it would be pretty easy to do that, but whats the fun in doing something that you know is going to work allready I'm not going to be actually trying this on anything, just thinking about it.
Unread 03-11-2005, 09:14
Electrical Engineer
Rookie Year: 1995
Jon,
I believe that any such an attempt would be violating the spirit and intent of the rules.
Years ago, Woodie and Dean asked us not to be lawyers. I would echo that sentiment.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 03-11-2005, 10:56
The motors can only draw their power (energy) from the victors
and you cannot build your own motors
adding additional coils to the motors is an interesting idea, but those coils would be dissapating energy into the motors (magnetic energy), which is not coming from the victors - so it violates the rules
you could come up with all sorts of creative ways to increase the power of your drive train, making a steam engine for example - but no matter how you convert stored energy into mechanical energy a motor is still a motor - if its supplying more power to the drivetrain, its a motor, and its against the rules.
Unread 03-11-2005, 12:43
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I disagree with Jack that it violates <R31> as written, however, it clearly violates the spirit of that rule, for whatever that's worth when it comes time for the inspector to make a ruling. Part of the problem is that circuits are defined in the rules in electrical terms ("as long as the electrical system is not modified", etc.), rather than (more comprehensively) in electromagnetic terms. What we really ought to see from FIRST is a clear indication of what modifications to the motor's magnetic circuit (which includes the ferrous metal case of the motor) are permissible. This would also instantly clarify the legality of 190's lathed-down CIM housings. Personally, I'd like to see something like "additional magnets, ferrous metals, or field coils (whether separately excited, or energized by the motor's magnetic field) are not to be placed within 0.25 in of the outer diameter of any motor, if their presence would cause a significant change in motor output", along with "modifications to the motor housing are permitted, provided that they do not cause a significant change in motor output or compromise the structural integrity or safety of the motor".
Returning to the original proposal, it seems to violate <R53>, which requires that custom circuits may not "[d]irectly affect any output devices on the robot, such as by providing power directly to a motor", though I suppose that a question could be raised as to whether "directly" includes magnetic fields, or merely refers to electrical conduction.
I don't think that this circuit exactly conforms to the intended applications listed in <R52>, but because the rules do not state "if it's not included, it's not allowed", we can only note that it doesn't conform to the stated intent. (Perhaps "may" should become "may only" in the second sentence of that rule.) Also, the sense of the term "outputs" looks like it means electrical outputs (judging by context), and therefore wouldn't cover the magnetic field.
Unread 03-11-2005, 12:53
Originally Posted by ConKbot of Doom
...we aren't supposed to open them up to mess with them,
here is where your thinking is slightly offtrack - we are not allowed to modify the motors to enhance their performace, whether you open them or not
if you add field coils to a motor, with the intention of altering its torque and speed characteristics, how can you say the motor has not been modified?
from Daves post in the motor bias thread:
In 2005, Rule <R31> stated the following:
<R31> So that every robot’s maximum power level is the same, the motors in the kit may not be modified except as follows:
• It is acceptable to modify the mounting brackets and/or other structural parts of the motors (output shaft, housing, etc.) as long as the electrical system is not modified and the integral mechanical system of the moving parts (bearings, bushings, worm gear output stages, etc.) is not changed or removed. ...
Unread 03-11-2005, 13:12
The sense of the word "modification" from <R31> seems to be referring to physical changes only. ("The intent is to allow teams to modify mounting tabs and the like, not to gain a weight reduction by potentially compromising the structural integrity of any motor.") We know, obviously, that they want to limit robots to a certain power output level, but they have only described physical changes to the motor that might cause this level to be exceeded. They don't actually mention entirely new components that exist outside of the intact motor.
Also, to preempt this question, I don't think that the external coils constitute a distinct additional (i.e. illegal) motor. They don't posess a rotor (unless the CIM is part of an assembly, which is a perverse way of looking at it, given that motors are typically considered to be components), so how can they be a motor? (No mention of linear induction motors, please; they're not relevant—but they do have the equivalent of a rotor.)
Now, one thing that I didn't address before: safety. By increasing the power output, you're also increasing the heat generated by the motor. Since we assume that the motor is designed for its rated power, and no more (even if there is a margin of safety, we're not privy to how big it is, and can't convieniently calculate it), it would be fair to assume that adding extra power could cause thermal damage to the motor. The increased risk of smoke and fire would likely be a fair reason to disallow it, unless, of course, the team using it could prove that it was safe (which would be challenging, I think).
Unread 03-11-2005, 13:48
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
OK, so I can see how this could possibly be illegal according to the FIRST rules.
So to satisfy my curiosity, would this actually increase the power of the motor? Electricity and I usually do not get along, but this sounds like a cool off-season project.
Unread 03-11-2005, 13:57
Not only do you have the above mentioned issues, but you have to insulate the wires or whatever else you use. That will also affect the motor, plus you get inspectors wanting to verify that yes,that is a CIM in there, plus the CIM may be counted as part of a motor assembly, so you get hit on making your own motor. I don't think it's worth the effort, because by the time you get through th inspection process and everything else, it'll be Friday afternoon... A better option for more power might be to just have another motor that engages only when you want it to. If you really want to get an answer to whether winding more coils around the motor is legal, talk to Q&A. Oh, and all this leaves out the possibility that this whole thing might not work.
Unread 03-11-2005, 15:44
Dave.Norton Dave.Norton is offline
FRC #1157
Dave.Norton is an unknown quantity at this point
Smile Re: Additional field coils around motors
The difficultly is the case is already the field return path and by and large any externally applied flux is going to be shunted around by the case without bothering with the rotor. Somehow you would need to get the additional flux into the internal flux circuit, but I can't think of a why to do that without violating the letter of the rules (let alone the spirit ).
Unread 03-11-2005, 21:46
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
So, if we fabricated a motor mount out of a steel band that wrapped around the CIM, the motor might have a slightly higher power output?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 03-11-2005, 23:04
In a post I'm too lazy to search for right now Joe Johnson said something to the effect of "if you can pick up a large paperclip with a motor, chances are the motor could benefit from an external flux yoke" (I think that's what it is called) "Torque can be increased up to 20% in some cases"
And you'll notice the FP motor has one of these doo-dads and apparantly it serves a very important purpose.
So, I haven't tried it, and I haven't yet learned about magnetic flux and whatnot (I think about 3 weeks away from learning about that in Physics) but it sounds logical and I'd definitely be willing to try it. Does anyone know if you can pick up a paperclip with a CIM?
Unread 04-11-2005, 00:08
the effect of increasing the strength of the field is twofold:
1. you will have more torque for a given voltage
2. your top speed will be lower
the reason for #2 is the stronger field will generate a larger counter-EMF, the back voltage that determines the motor top speed.
Looking for Official FRC Competition Field plans sanddrag General Forum 6 17-10-2005 07:58
Do the CIM motors emit a magnetic field? JulieB Motors 17 27-01-2005 12:59
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
How does one go about ordering more motors... Team852 General Forum 3 27-01-2003 14:37
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
