Go to Post Clearly they're releasing the game hint on 12/21/12 because they know the world's going to end, and they want to keep FIRSTers happy and distracted until the very end. - Kevin Sevcik [more]
Unread 03-11-2005, 14:58
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Extending a cantilevered drive shaft.
Here's a sticky situation that may or may not have an elegant solution.
I'm working to development a prototype drivetrain that my team will be building over the next two months with the hope that we will run into and solve any problems that crop up long before the short 2006 season starts. Among the requirements I imposed on myself, it must be easy to manufacture, cheap, easy to assemble and disassemble, and robust.
As such, I've elected to use a turn-key transmission. This iteration is based on the AM Gearbox from AndyMark. As things turn out, the output shaft is a bit shorter, I think, than that of the kit-provided transmissions.
As you can see, I have a sprocket hanging in space right now that probably won't stay put -- no matter how hard we all concentrate. I need to somehow extend the shaft to support that sprocket without making a new shaft.
What I anticipate is creating a cluster of two sprockets by bolting through each of them and a spacer so as to achieve and maintain the 2" separation I require. The end of the gearbox output sprocket appears to have a threaded hole, though Andy's drawings don't call it out specifically. I was considering then bolting through an extension and into that threaded hole, effectively extending the shaft length by 5/8" or so.
Is this a 'really bad idea'? I'm hoping that bolting both sprockets together will help to minimize the shear the currently unsupported sprocket exerts onto the extension it would sit upon.
Any ideas?
I know this is a really bizarre, obtuse question. I just wanted to see if I could get some additional opinions about best practices in cases like these so I am not later forced to abandon all of the neat design features this chassis has because of something as inconsequential as shear
--Madison--
...down at the Ozdust!
Unread 03-11-2005, 15:13
Re: Extending a cantilevered drive shaft.
From the drawing you have, I can't really see much. Imean, I can sort of understand, but it's hard to see. It looks like both sprockets are supported in the drawing. Could you show us another angle of the gearbox, say an end view or isometric? That way we can all see more clearly and provide better help.
Unread 03-11-2005, 15:18
Madison's Avatar
FRC #0488 (Xbot)
If you look at the topmost image, look closely at the shaft between the two sprockets. It ends before entering the leftmost sprocket. It's close, but close isn't good enough
The second image shows a really quick rendition of my proposed solution. The red piece represents the extension that would be bolted into the end of the existing output shaft. The leftmost sprocket from the top view would rest wholly on the red extension piece.
--Madison--
Unread 03-11-2005, 16:11
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
A picture paints a thousand words.
I hate to tell you this, but I just don't see any way the screw that holds the extension in place being able to handle the torque that will be applied to it. In effect, that screw will be all that is driving the outboard sprocket and it's applied load.
Now, if the extension was to have a section that fit over the shaft protruding past the first sprocket with a key way slot to drive it, no shoulder on the outboard side so the outer sprocket could then be mounted to it, and finally the center drilled through so that a screw passed through a washer , through the extension and into the trans output shaft to hold it all together, then that "might" work. Clear as mud??
Unread 03-11-2005, 16:20
Madison's Avatar
FRC #0488 (Xbot)
I understand that the screw alone would shear under the load exerted by the chain onto the outermost sprocket. I was hoping that, by bolting the sprockets together, those bolts would transmit some of that load onto the main shaft. I understand the solution you propose as well, though I don't believe we're capable of broaching a keyway and thus, it's a bit harder to implement.
I may just opt for a different chain routing so as to completely eliminate the outermost sprocket.
--Madison--
Unread 03-11-2005, 16:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Since you mentioned simplicity, I wont go into the welding options. If you have access to a mill and either a skilled operator or DRO then what you could do is drill four very precise holes in the sprocket that rides on the shaft and tap them. It is Very important that the bolt circle that these holes lie on is concentric with the bore. Then, make a spacer with a similar hole pattern but make them through holes just barely large enough to clear the screw. Then on your outboard sprocket, do the same thing. Bolt it together (and tight) and now you have a double sprocket to the spacing of your liking and you need not do anything to the shaft. The outboard sprocket is drven by the screws going through it. Remember to make sure you select a bolt hole circle such that the heads of the bolts do not interfere with the chain. At least that's what I would do, given the design considerations.
EDIT: A way to do this without machine tools would be to clamp both sprockets and the spacer together with a bolt through the bores (and a nut on the other side). Get everything lined up and then tighten up that bolt real good. Make white paint line down all three pieces so you can line them up easily later. Then set up this assembly on a drill press and drill through all three at once with the bit that the tap requires. Once you have the four holes, pull the assembly apart and drill one sprocket and the spacer to just clear the bolts and tap the other sprocket. Assemble the three pieces with your four bolts making sure your white index marks line up. Having a shaft in the bore while tightening is a good idea btw to ensure concentricity
Unread 03-11-2005, 17:22
billbo911's Avatar
OOOpps, I didn't catch this part. My bad.
Your suggestion is another option that should work.
In Sanddrag's post, he mentions a couple ways to implement this fairly easily. The edited version really would be a fairly simple and effective way to do it with very little tooling required.
I tell you, that Sanddrag, what a genius!!
Unread 03-11-2005, 17:31
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Maddie, this is a neat design. Thanks for using the AM Gearbox into this mechanism.
I agree that bolting the sprockets together will work, but that second sprocket is a looong way from the gearbox.
Here is another solution: Make a longer output shaft. That shaft is simply 1/2" steel hex stock (we use 4140, but you don't have to). You would simply need to turn down the hex to fit into the 1/2" id gears and add a keyway in the right spots.
Not only may this be easier than some other solutions, but you can support the far end of the output shaft this way.
Good luck,
Andy
Unread 03-11-2005, 18:03
Madison's Avatar
FRC #0488 (Xbot)
Do the little posts shown in this picture serve any purpose? It's hard to tell from the plans available on the site. They make the part look harder to manufacture, at the very least
If it's just a turned hexagonal shaft, we should probably be able to make that. I'll have to see about the keyways, though.
--Madison--
Unread 03-11-2005, 20:01
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Can you turn down the hubs enough to atleast get and E-clip on the shaft?
Unread 03-11-2005, 20:24
Yes, that's the one thing I wasn't able to add before the battery on my pocketpc died earlier today. I do believe it will work, but you shouldn't put too much tension on the chain. I was also going to add that maybe you can still make something to screw into the end of the existing shaft to fill the empty void in the outside sprocket which will help things a little.
And I too am curious as to what that little peg is in the hex portion of the shaft in that AM photo.
Unread 03-11-2005, 20:43
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
If you don't have a broach set it is possible to mill a keyway into the shaft. Not sure of the resources available to your team but I wanted to bring up that option.
Not sure why you recommend an E-clip? An E-clip will hold a sprocket on but won't drive it. You need a keyway or what Sanddrag mentioned to do that.
Also milling down the sprockets will eliminate the 2" separation Maddie requires and planned for.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 03-11-2005, 21:08
Actually, a keyway is usually milled/cut in a shaft and broached in a bore.
Now, for making a keyway in a bore without an arbor press. There is the possibility you can use something different for your press, like a mill or a drill press. Although I wouldn't recommend it. It could damage the machine. Another possibility would be to use a vise (such as a mill vise) that can open it's jaws wide enough to fit the gear and broach. Close the vise, and it presses the broach through. A precision vise can make an excellent press in a pinch.
For making a keyway in a bore without a broach, there is a way you can sort of "fudge" it. We've done this before and haven't had any real problems. What you can do, is set up the sprocket/gear on a mill so that it's face plane is parallel to the plane of the mill table. Using an edgefinder (and DRO) or a drill blank, locate the center of the gear and lock one of your mill axes in place. If you are using an 1/8" key, put a 1/8" endmill in a collet in the machine. Move the other mill axis such that the center of the endmill is directly above the point on the circumference of the bore. Take a plunge cut nice and easy straight down. (when I say easy I mean it. Touch the downfeed handle with something like the weight of a couple feathers. Those 1/8" tools are quite fragile) Now, move the axis of the mill table that is unlocked another 1/16" into the gear and take another plunge cut. You now have a 1/16" by 1/8" rectangle of material gone (just like a regular keyway) with the added "bonus" of a half circle on top. The key will fit just fine and be able to transmit torque reliably. However, over time it will want to move into that half circle area. So, fill the half cirle with something, anything, a toothpick, piece of paperclip, epoxy, whatever.
Alternatively, you could reduce the "rectangle" portion of this keyway and grind the key rounded somewhat. Or maybe get a 1/8" by 3/16" key, and grind it round one one side so it fits perfectly into your rectangle with half round on top keyway.
EDIT: If you use this method to make a keyway, make sure you are using a center cutting endmill.
Unread 03-11-2005, 21:55
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Something I've been known to try is to give the mill table a little horizontal motion as the tip of the end mill is being very lightly plunged into contact with the workpiece (it helps to mill a small flat on the top of the piece first, to avoid trying to do this on the rounded surface). Where very fine precision isn't necessary, this can produce acceptable results. I've done it with 1/8" and 9/64" keyways, with three-fluted non-centre-cutting endmills, and it works well enough. Workpiece materials were 416 stainless, if I remember correctly.
(Edit: For a non-centre-cutting endmill like the one that I described above.) Work slowly, and remember to never try to plunge the end mill straight down, even after the cut starts. Let it cut at an angle.
Last edited by Tristan Lall : 04-11-2005 at 00:14. Reason: Clarified, per sanddrag's reply.
Unread 03-11-2005, 22:03
That is simply a 3/32" roll pin. It serves the purpose of holding a gear in place on the shaft. It is much cheaper than machining a step.
Andy B.
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
If you could change one thing.... Koko Ed General Forum 48 31-03-2005 19:23
Problem with 5/8 in. shaft in this years kit echos Kit & Additional Hardware 5 14-01-2004 21:21
drill motor drive shaft attachment archiver 2001 1 23-06-2002 22:32
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
